Old 09-24-2021, 05:01 PM   #1
Oldgearz
Default Floaters or Not?
I've never looked at a Model A brake set up before, and can't find pictures showing brakes with floaters and brakes without floaters. So when I pull my front drums tomorrow and look inside, how can I quickly recognize if I'm looking at a floater setup?
Oldgearz is offline   Reply With Quote
Old 09-24-2021, 05:20 PM   #2
Herb Concord Ca
Default Re: Floaters or Not?
First there are 2 types of floaters. One costs $25-30 and has a floating pin in the actuating wedge. the other type, Flathead Ted's costs $200 or more and doesn't use the upper long spring. Search this website for more floater information.
Herb Concord Ca is offline   Reply With Quote
Old 09-24-2021, 05:40 PM   #3
Oldgearz
Thanks Herb. I searched but can't find pictures. Schematics are hard for me to visualize. I'll be able to see what is going on by your description. I'm up to that!
Old 09-25-2021, 07:25 AM   #4
rotorwrench
rotorwrench's Avatar
This is a link to model A times article on Flathead Ted's site.
http://www.flatheadted.com/images/st...winter2007.pdf
Old 09-25-2021, 07:33 AM   #5
alexiskai
alexiskai's Avatar
If the Flathead Ted floaters are present, the adjusting wedge turns smoothly, rather than ratcheting like the stock wedge, so you would know that without taking the drums off.
Old 09-25-2021, 07:33 AM   #6
Hotrodfil
Hotrodfil's Avatar
Teds floaters swap the upper adjuster for a new one with a thin locknut so you can tell without removing the drum.
Hotrodfil is offline   Reply With Quote
