06-19-2021, 03:39 PM | #1 |
Mitchell overdrive in 36 ford coupe
Have the Mitchell overdrive units been changed or modified or will I still have to modify my rear floor by cutting an opening to make room? I have a 36 standard coupe.
Thank You. Frank |
06-19-2021, 07:52 PM | #2 |
Re: Mitchell overdrive in 36 ford coupe
You'll need to cut the floor.
06-19-2021, 08:17 PM | #3 |
Yes as above, you will need to open up the floor where the trans tunnel meets the step up in the rear floor. I friend of mine had to do this on his coupe. I dont believe the overdrive box has been modified. Call them and ask the question. Regards, Kevin.
06-20-2021, 07:38 AM | #4 |
Yes, you will have to modify the floor in one area.
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
06-20-2021, 09:32 AM | #5 |
FYI, I put one in my 39 Std. Coupe and the only thing I had to do was to hammer the corners at the tunnel just a little for clearance but I didn't have to cut any of the floor.
06-21-2021, 05:11 AM | #6 |
