Old 10-01-2020, 07:12 PM   #1
Will D
Will D's Avatar
Default Carb gasket surface
If I have minor pitting on Holley 94 91-99 Chandler groves gasket mating surfaces, can i safety go thru the sandpaper up to a polish to resurface the surfaces? Or will it alter the operation of the carb? I wouldn't be removing to much material but how little is to much?
Will D is offline   Reply With Quote
Old 10-01-2020, 09:06 PM   #2
JSeery
JSeery's Avatar
Default Re: Carb gasket surface
Might not be the best practice, but I would think a little sealer would take care of any pitting.
Old 10-01-2020, 09:15 PM   #3
flatjack9
flatjack9's Avatar
I wouldn't think you would cause any problems. I routinely sandpaper mating surfaces to be sure they are flat.
Old 10-01-2020, 09:20 PM   #4
JSeery
JSeery's Avatar
I know of the cheap holley 4-barrels you about have to on most of the mating surfaces!
Old 10-01-2020, 09:44 PM   #5
51woodie
51woodie's Avatar
I have a 12" x 12" piece of plate glass that I put various grits of emery sheets on, to cleanup and true mating surfaces when I need to. Never had a problem, as there is not much material removed.
51woodie is offline   Reply With Quote
Old 10-02-2020, 12:39 PM   #6
ford38v8
ford38v8's Avatar
Minor pitting is not a problem. What is a problem is when the screws have previously been tightened too tight, causing warpage of the mating surfaces. 51Woodie has the better solution (flat surface with emery paper) rather than hand sanding, as the two mating surfaces must be flat, without hills and gulleys.
Alan
Old 10-04-2020, 07:38 PM   #7
Talkwrench
Talkwrench's Avatar
This is fine ^, use a small amount of grease on the gaskets and dont overtighten.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 10-05-2020, 08:39 AM   #8
Jacques1960
Jacques1960's Avatar
Be sure to use some cutting oil or MMO on your abrasive; helps the honing process. Like the glass sheet idea !
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 10-05-2020, 09:00 AM   #9
JSeery
JSeery's Avatar
And be careful you don't "rock" the part as you slide it back and forth. Very easy to do.
Old 10-05-2020, 09:09 AM   #10
flatford8
flatford8's Avatar
I use a figure 8 pattern, along with making sure to keep it flat......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 10-05-2020, 10:10 AM   #11
uncle max
uncle max's Avatar
Also important to not overtighten the airhorn screws.
I use an aircraft in/lb torque screwdriver, set to 7 in lbs, just enough to flatten the lock washers.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 10-05-2020, 10:18 AM   #12
19Fordy
19Fordy's Avatar
Would it be ok to apply a light covering of JB Weld and then sand it smooth?
Also, apply sealer to gasket surface.
Old 10-05-2020, 11:13 AM   #13
uncle max
uncle max's Avatar
JB weld on carburetors is good for 10,000 miles or 10 minutes, whichever occurs first.
Old 10-05-2020, 11:37 AM   #14
Russ/40
Russ/40's Avatar
Something I have done that stops the seeping stains and gas smell, is to use the light liqued super glue and let it wick into the gasket edges after assembly. Especially on the jet plugs at the bottom of the bowl.
Russ/40 is offline   Reply With Quote
Old 10-05-2020, 07:18 PM   #15
russcc
Vern Tardels book, How to Build a Traditional Ford Hot Rod, on page 112 shows how Vern dresses carb surfaces w/400-grit paper on a sheet of glass. That should be testimony enough.
russcc is offline   Reply With Quote
Old 10-05-2020, 09:49 PM   #16
Will D
Will D's Avatar
Thanks for all the input fellas. I went with the glass and wet sand 400 up to 1200. Turned out real nice. Checked with straight edge and used high intensity fiber optic light to shine inside to check for light leaks from the outside. Would have been even better if I would have tested my float before ordering the carb rebuild kit. Figured id be a fool to put it back together without doing so. Did the hot water test, turns out it has a few pin holes.... got a new one on order today.
Old 10-06-2020, 02:47 PM   #17
1952henry
1952henry's Avatar
You can make a jig, mounted in a bench vice, and apply a little heat and pressure. The warped surface will straighten out. Haven't had to do it on Holleys, but have done it on 97 tops.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 10-06-2020, 04:47 PM   #18
solidaxle
solidaxle's Avatar
Try this it's fuel resistant
solidaxle is offline   Reply With Quote
