Old 05-03-2017, 01:50 PM   #21
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Default Re: Mid west rain
Had to venture out...Rte 100 from Hardin north will soon close, Illinois River has arrived at the edge of the pavement. Water here on the Mississippi River side keeps rising, I thought it had crested but it's moving up again. Temps dropping too, heat back on, coffee on and eBaying to pass the time!!!!
Have a great day!!!!!!!!!!!!
"Bullshit and Brilliance Comes with Age and Experience"
"Hey Lady, ya wanna buy a Grit?"
"If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers
31 Model A is offline   Reply With Quote
Old 05-04-2017, 08:06 AM   #22
iron mountain 1
Do any of you guys know if the model T Club is still having their swap meet Sunday 5/7/17 at the race track? or is the track flooded? thanks Kris
iron mountain 1 is offline   Reply With Quote
Old 05-04-2017, 08:11 AM   #23
31 Model A
31 Model A's Avatar
I personally don't know but here are some contact numbers.
http://stlmodeltclub.org/contactus.html
Old 05-04-2017, 09:08 AM   #24
Jeff/Illinois
Jeff/Illinois's Avatar
We're maybe ninety miles north of all this. It's pretty bad.
4 more inches of rain coming today down there. It's setting up like back in '93 when all that rain kept dumping on the upper Midwest/Minnesota areas and the Mississippi went WAY over flood stage set a lot of records.
Wonder if a Model A could make it thru the water running over the roads? Wouldn't want to be the one to try it.
Jeff/Illinois is offline   Reply With Quote
Old 05-04-2017, 09:38 AM   #25
31 Model A
31 Model A's Avatar
At 40 feet water will be touching Sarah's tires, I've a ways to go yet but it continues to rise. Route 100 out of Hardin heading north is now closed, that's the Illinois River side.
https://www.bing.com/videos/search?q...CE&FORM=VRDGAR
Old 05-04-2017, 09:47 AM   #26
larrys40
At this point it is still on as far as I know. I have two vendor spaces and one of the guys I know well who runs the swap hasn't called to say otherwise.
If it quits tonight as they say it would have two days to dry out. for sure it is bad down here right now. Ed may have to figure out farming to eat as he is getting cut off from the main land one road at a time. Only really one left for him now ( maybe the ferry if running).
It's usually a pretty good swap meet. One of only a couple left around here so it you need "A" parts come on in. I will post asap if I here of any news.
Larry Shepard
larrys40 is offline   Reply With Quote
Old 05-04-2017, 09:53 AM   #27
George Miller
George Miller's Avatar
Going to Missouri Sunday. Do you think the Roads will be ok by then.
George Miller is offline   Reply With Quote
Old 05-04-2017, 10:36 AM   #28
31 Model A
31 Model A's Avatar
50/50 chance George....depends upon a lot, some towns have crested, some have a way to go. This 2-4 inches we have received additionally in the last 36 hours has slowed the cresting down quite a bit.
Old 05-04-2017, 10:38 AM   #29
31 Model A
31 Model A's Avatar
Larry Shepard
Frig is full...........credit cards still holding out, thank you Al Gore, without the internet, I wouldn't have Ebay to pass the time!!!!!!!!!!!!!!
Old 05-04-2017, 11:12 AM   #30
George Miller
Thanks
Old 05-04-2017, 11:26 AM   #31
Seth Swoboda
Seth Swoboda's Avatar
Depends on where you are headed in Missouri. There are lots of road closures state wide that you should be able to identify using an internet search. Perhaps starting with Missouri Department of Transportation. You will be able to cross the Mississippi River in the St. Louis area, however there are some main and secondary roads that are impassible.
Seth Swoboda is offline   Reply With Quote
Old 05-04-2017, 01:08 PM   #32
JDupuis
JDupuis's Avatar
I'm having to wear a hat. All this moisture is wreaking havic on my comb-over. . Stay dry! Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 05-04-2017, 01:59 PM   #33
George Miller
It is just down from Columbia. Will be coming through St Louis.
Old 05-04-2017, 02:17 PM   #34
Seth Swoboda
I64 to I70, assuming. You should be fine on those interstates.
Old 05-04-2017, 02:18 PM   #35
George Miller
Thanks for reply.
