Old 08-25-2021, 08:36 PM   #21
Ronnieroadster
Ronnieroadster's Avatar
Default Re: 400jr cam
Originally Posted by tubman View Post
Lots of bad things happening at Isky during the '90's. There were times when, unless you degreed the cam, there was no assurance it was ground right. Hopefully they have got it straightened out.
Well sadly not all is right at Isky. Working on a recent build using a new Isky cam that was a new casting upon checking the cam timing per the instructions it degreed in at 119 on the CL. In other words it was way off the timing card specs at 119 the engine would have been a dog. Now most people would never take the time to degree in a cam on a flathead since its extremely difficult to make an adjustment however its worth the effort even though its definitely time consuming.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 08-25-2021, 10:38 PM   #22
Ol' Ron
Ol' Ron's Avatar
Back in the day, we had adjustable cam gears. I think I have one someplace. However we'd elongate the cam bolt holes and use sterwashers to hold them in place, and it worked.. Unfortunately moving the cam around didn't do much. Gramps..
Old 08-25-2021, 10:50 PM   #23
Pete
Pete's Avatar
That is very true with street grinds.
With a radius lifter grind moving the cam 1 degree can move you from first to second place.
Old 08-26-2021, 07:43 AM   #24
Bored&Stroked
Bored&Stroked's Avatar
Hey Pete, if you're running a 404-A grind, what type of cam timing do you like to setup the cam for? I know that is a very broad question (depends on the application, track, etc). am just interested in your thoughts on the subject . . . the wisdom of experience!
Old 08-26-2021, 12:59 PM   #25
frnkeore
frnkeore's Avatar
Ronnie, are you talking 119 for the LSA or the ICL?
ICL can be changed but LSA can't.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 08-26-2021, 03:25 PM   #26
Pete
Pete's Avatar
I don't get much feedback lately but the last I heard, from 2 guys that have engines I did in the near past, one is running the cam 2 degrees retarded and the other, straight up.
It makes a noticable difference on some tracks, especially with the tires allowed now.
Thread Tools
Display Modes
