Old 10-07-2021, 05:08 PM   #1
fordor
Default 34 hood
Trying to find out the length and diameter of the two rods that go to the top part of the hood(not the side rods that connect the side hood and top hood). They go thru the piano hinge and attach at the radiator and cowl. Also how is the stainless trim piece that goes down the center attached?
Thanks,
Bob L.
fordor is offline   Reply With Quote
Old 10-07-2021, 06:02 PM   #2
STAN WHITE
Default Re: 34 hood
Bob The center item that holds the two top halves of hood is a stainless item. The hood is designed to just slide it on one side and then with help from someone you can slide the other side on. now you havea hood top, you will need help to install on the car. one person on one side and one on the other. There are two pcs that you will need they are both the same, one goes on the top of firewall and is attached with flathead screws & nuts the other attaches to the top oo a 34 radiatoir just flathead screws no nuts required. The part tha attaches to the top center of firewall should go on first. Hope this helps. These parts are available from a number of sources!
STAN WHITE is offline   Reply With Quote
Old 10-07-2021, 06:22 PM   #3
STAN WHITE
Default Re: 34 hood
Bob I forgot to say I am sure that I have what you need. I have done a couple of 34s and have extra parts! Stan 775 265 5333. What you need can be obtained @ Drakes old ford parts in oregon
Old 10-07-2021, 11:52 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 34 hood
Thanks,
Bob L.
Bob .....There is a center, stainless strip that slides over the two curled edges at center of hood tops, BELOW! Hope these pics help. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-08-2021, 12:53 AM   #5
cas3
Default Re: 34 hood
If you are doing a fancy car, lots of folks use a stainless rod thru the piano hinge so no rust from a steel rod bleeds thru on your nice paint
Old 10-08-2021, 07:03 AM   #6
fordor
Default Re: 34 hood
So what is the length and diameter of the rods? Thanks for the explanation. I see how it goes together now.
Old 10-08-2021, 07:37 AM   #7
deuce lover
deuce lover's Avatar
Default Re: 34 hood
1/4" X 38 1/4" - if you have the hood you will know the length anyway. Home Depot used to have 1/4" stainless rod stock at one time.
Old 10-08-2021, 09:41 AM   #8
fordor
Default Re: 34 hood
So the only thing holding the two tops of the hood is the stainless trim piece?
Old 10-08-2021, 09:51 AM   #9
deuce lover
Default Re: 34 hood
Yes and most vendors have it in stock.
Old 10-08-2021, 02:10 PM   #10
alchemy
alchemy's Avatar
Default Re: 34 hood
If you can find an original center stainless strip, I highly recommend it. They fit much better than the repros I've encountered.
alchemy is offline   Reply With Quote
Old 10-08-2021, 09:36 PM   #11
fordor
Default Re: 34 hood
Thanks everyone for your help. I have the original stainless. Now I have figured out how it all goes together with everyone's help. Again thank you.
Bob L.
