Old 09-29-2016, 02:58 PM   #1
PO51
PO51's Avatar
Default Juice brakes
I'm thinking of putting juice breaks on a modified 4 banger RPU. Are their any books or good articles on this conversion? Looking for options on where to mount the master cylinder and pedal. Keeping stock clutch pedal with mitchell synchro trans.
PO51 is offline   Reply With Quote
Old 09-29-2016, 03:22 PM   #2
Jason in TX
Jason in TX's Avatar
Default Re: Juice brakes
http://www.lainefamily.com/ModelAFil...akeUpgrade.htm
http://www.mtcarproducts.com/MODEL-A-KIT.html
(click on each link below...)
https://www.clingsaftermarket.com/pr...rakes&subcat=1
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 09-29-2016, 04:01 PM   #3
Charlie Stephens
I like the battery box that is built up to incorporate the master cylinder mount but don't know a supplier at this time. Call around, start with Bert's. Note tat some of the boxes are not strong enough and flex.
Charlie Stephens
Old 09-29-2016, 06:58 PM   #4
miff
I put juice brakes on my speedster very pleased . I would next time just buy the full kit from MT car products . It's pricey . But in the long run it will save you a lot of time . Plus they where very helpfull .Inmy 30 roadster I have orgianal brakes . Have flathead Teds set up .
miff is offline   Reply With Quote
Old 09-29-2016, 07:56 PM   #5
C26Pinelake
Total kit at MT is $3400 dollars plus shipping. Wayne.
C26Pinelake is offline   Reply With Quote
Old 09-29-2016, 07:56 PM   #6
eagle
eagle's Avatar
If you put half as much work into your mechanicals you would have great brakes that can set all winter and not get all rusted up.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-29-2016, 07:59 PM   #7
2manycars
2manycars's Avatar
Try an inquiry on the HAMB. Link is on the bottom of the main fordbarn page.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 09-29-2016, 08:01 PM   #8
160B
160B's Avatar
I agree 100%
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 09-29-2016, 08:02 PM   #9
Jason in TX
I agree with eagle. Replace the worn parts on the mechanicals for much cheaper and have brakes that stop a stock model a wonderfully
Old 09-29-2016, 08:31 PM   #10
Terry, NJ
Terry, NJ's Avatar
I have both types and see no advantage to the hyds. I actually prefer the Mechanical over the Hydraulics.
Terry
Terry, NJ is offline   Reply With Quote
Old 09-29-2016, 09:24 PM   #11
denis4x4
denis4x4's Avatar
Obviously, I'm doing something very wrong as the hydraulic brakes on both of my A's neither leak or bind up due to rust. Can somebody help me here?
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 09-29-2016, 09:40 PM   #12
Jordan
Jordan's Avatar
My brothers Coupe has had hydraulic brakes for 20 years now- no problems. I've had hydraulic brakes on my car for 2 years, no problems. And my car has sat more that it's been driven in the past two years.
Cowtown A's
Jordan is offline   Reply With Quote
Old 09-29-2016, 09:41 PM   #13
C26Pinelake
Be patient, it will happen ! Wayne
Old 09-29-2016, 10:07 PM   #14
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by 160B View Post
I agree 100%
Terry
Add me to the list. It's a lot of money to spend, but if it will get you on the road more then follow the links above. Several vendors sell complete kits.
Old 09-30-2016, 10:57 AM   #15
Jim Brierley
Go with the hydraulics! There is a reason all cars use them today, they are better and require less maintenance. I've had them on my widebed since 1958. I did have one cylinder rust-up but now run silicone fluid, end of problem! I also have them on my tudor and Vicky. Mostly I made my own mounts, using a 1939 pedal assembly as a base but have used Cling's products which fit very nicely. If you drive your RPU at all, hydraulics are the way to go.
Jim Brierley is offline   Reply With Quote
Old 09-30-2016, 11:56 AM   #16
Terry, NJ
Terry, NJ's Avatar
I have seen one well known restorer say that the Mechanicals can be locked up. Now whats a Hydraulic going to do better than that? Locked up with mechanicals or Hydraulics is still locked up. Where do you go from here? Bigger (wider) tires? Bigger drums? I don't know.
Terry
Old 09-30-2016, 11:57 AM   #17
Mitch//pa
Originally Posted by terry, nj View Post
i have seen one well known restorer say that the mechanicals can be locked up. Now whats a hydraulic going to do better than that? Locked up with mechanicals or hydraulics is still locked up. Where do you go from here? Bigger (wider) tires? Bigger drums? I don't know.
Terry
abs
Old 09-30-2016, 12:04 PM   #18
CarlG
CarlG's Avatar
Charlie Stephens
This one is one of the best made:
http://www.ebay.com/itm/272385702072
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-30-2016, 02:02 PM   #19
SwansEarlyFord
Why do people say "I can lock up all four wheels" locking up wheels and skidding is not in any way stopping. Once again, the best model a brakes are stock ones set up right.
SwansEarlyFord is offline   Reply With Quote
Old 09-30-2016, 02:38 PM   #20
biggieou
Hahaha, I hear ya! I'm totally doing something wrong.
1931 Model A Victoria
1950 Mercury 8
Member: MAFCA, MARC, Northern Ohio Model A Club
www.northernohiomodela.com
biggieou is offline   Reply With Quote
