Old 10-27-2014, 05:02 PM   #1
PO51
PO51's Avatar
Default Horn
I have a sparton horn that I installed today, took the back cover off, but I'm not sure where the wire attaches to the horn?
PO51 is offline   Reply With Quote
Old 10-27-2014, 05:27 PM   #2
JohnLaVoy
JohnLaVoy's Avatar
Default Re: Horn
There should be two spring clips a wire goes under each of the clips.
JohnLaVoy is offline   Reply With Quote
Old 10-27-2014, 06:40 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Horn
The wires point at each other, in other words the form one straight line, and not parallel railroad tracks.
Old 10-27-2014, 08:22 PM   #4
PO51
PO51's Avatar
Default Re: Horn
Anybody have a picture?
Old 10-27-2014, 11:34 PM   #5
Tom Wesenberg
Default Re: Horn
See how the wires poke in from the outer ends, where the metal clip folds over.
Old 10-28-2014, 12:08 AM   #6
PO51
PO51's Avatar
Default Re: Horn
Thanks for the input, Tom thanks do much for the Pic!
Steve
Old 10-28-2014, 04:41 AM   #7
Charlville
Charlville's Avatar
Default Re: Horn
I had some contact issues and did this, not standard I know but works well
http://automotiveamerican.com/2014/0...t-of-the-time/
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
Charlville is offline   Reply With Quote
Old 10-28-2014, 10:56 AM   #8
700rpm
700rpm's Avatar
Default Re: Horn
So now you must unsolder and resolder the wires any time you remove the horn. I would advise against doing this type of "repair," and instead fix the horn so it would work as it was intended to work.
Ray Horton, Portland, OR
Old 10-28-2014, 12:07 PM   #9
Charlville
Charlville's Avatar
Default Re: Horn
No, I have bullet connectors outside of the horn for easy removal, works for me so just sharing.
Kevin Flood
West Berkshire UK
Old 10-28-2014, 03:09 PM   #10
700rpm
700rpm's Avatar
Default Re: Horn
Ah. Sorry. The photo looks like the wires are soldered in.
Old 10-28-2014, 04:12 PM   #11
Charlville
Charlville's Avatar
Default Re: Horn
Hi Ray
You are correct the wires are soldered to the tabs, but with detachable connectors at the other end of the wire. I do appreciate the sentiment regarding originality however. My horn was in such a state this worked out for me, but it's not how Henry did it.
Kevin Flood
West Berkshire UK
Old 10-28-2014, 04:17 PM   #12
CarlG
CarlG's Avatar
Default Re: Horn
Hi Ray
I did this same thing for my headlights as well.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-28-2014, 04:31 PM   #13
Charlville
Charlville's Avatar
Default Re: Horn
Me too on the headlamps
Kevin Flood
West Berkshire UK
Old 10-28-2014, 05:14 PM   #14
Colonel
Default Re: Horn
Does it matter which wire goes right or left at the horn hookup?
Colonel is offline   Reply With Quote
Old 10-28-2014, 10:06 PM   #15
Tom Wesenberg
Default Re: Horn
No, it doesn't matter. The motor will still spin the same direction.
Old 10-28-2014, 10:46 PM   #16
PO51
PO51's Avatar
Default Re: Horn
Thanks for everyone's help getting the truck ready, got the horn to work this afternoon. Truck is on the trailer {not reg}Looks like it came out of field where it might have been sitting for 40 years. Of to Church tomorrow afternoon for trunk or treat with the kids. Scarecrows, pumpkins, and hay in the bed!
