10-03-2021, 10:23 PM | #1 |
Antique Engine Rebuilding
Rumor that they are going out of business the end of the year! Anyone else heard that?
10-04-2021, 04:52 AM | #2 |
Re: Antique Engine Rebuilding
Not a rumor, Rich is retiring.
"The more things change, the more they stay the same." |
10-04-2021, 07:13 AM | #3 |
Yep X 2. Rich is retiring. Heard it from a man who works for Rich.
10-04-2021, 10:49 AM | #4 |
Does that jeopardise the availability of his insert rod beatings?
10-04-2021, 01:23 PM | #5 |
I have been wondering that too - will he continue to make them? Should have asked him a few weeks ago.
10-04-2021, 02:32 PM | #6 |
Paul in CT |
10-04-2021, 03:03 PM | #7 |
10-04-2021, 05:40 PM | #8 |
Rich's parts business is a separate thing, He is actively trying to sell that now..
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
10-04-2021, 06:15 PM | #9 |
Let me get this straight. So the rods and bearings sold by the likes of Snyders are made by Rich and is he the maker of the main bearing inserts for the likes of the Burlington or Scat crank shafts?
If yes to the above, I assume I can buy direct from him. Yes/no?
10-04-2021, 06:46 PM | #10 |
You’d think Snyder’s or Bert’s would pick it up if not overpriced.
I’ve had numerous situations but the numbers just absolutely sucked. The ROI was just no where close |
10-04-2021, 07:05 PM | #11 | |
10-04-2021, 07:06 PM | #12 |
Correction: Should read just Central time, not eastern central time. Sorry.
10-04-2021, 08:56 PM | #13 |
Thanks Mike. I'll get up early (I hate that!) and ring him soon.
10-05-2021, 02:58 AM | #14 |
https://www.antiqueenginerebuilding.com/highwaycar.html
Previously if you wanted a Burlington crank in a rebuilt engine for us here in OZ it was probably worth just getting a rebuilt short block with hi comp head, Stipe cam and lightened flywheel all shipped by sea. Down left on the website are the parts. Probably best to go with a new engine now tho ... |
10-05-2021, 05:26 AM | #15 |
SYNCHRO, I have Snyders rods and inserts in my roadster. They are not from AER. The inserts have side thrust walls, imitating the original Ford rod Babbitt. AER inserts do not.
I don't know if this is a good thing or not, since most common modern shells do not incorporate side thrusts. SAJ in NZ |
10-05-2021, 04:09 PM | #16 | |
10-05-2021, 08:08 PM | #17 |
He's selling to somebody in Indiana. The guy is working with for a month or so to learn how he builds engines.
10-06-2021, 02:39 AM | #18 |
Synchro I was referring to the conrod insert shells 9 which have 2 side thrust faces moulded in to each one. Not crankshaft end thrust babbit replaced by bronze thrust washers.
SAJ in NZ |
10-06-2021, 11:56 AM | #19 |
Rich was at Gilmore/Hickory Corners two weeks ago at the Model A Ford Museum. He had the new buyer with him and he was introducing him to folks there. The buyer runs a machine shop in Blufton, Indiana, just south of Ft. Wayne. I'm not sure of the timing on all of this. The small parts is a separate business and is for sale.
10-06-2021, 02:27 PM | #20 |
Hoping the new owner keeps AER name and web site, sounds like the new owner working with Rich it will flawless turnover
