06-29-2021, 08:14 PM | #1 |
Rumble Seat Cushion fastener
Rumble Seat - Help
I asked this question before, but I did’t get a clear understandable answer? I have recovered the old spring area and I don’t know how or what mechanism is used to keep the bottom cushion from sliding forward. Can someone explain what device is used and if possible send a photo picture. There are all new floor boards and rumble seat bottom welled in. The back cushion has tabs and they slide in on the top section of the door. Last edited by dlfrisch; 06-30-2021 at 07:16 PM. |
07-01-2021, 08:36 AM | #2 |
Re: Rumble Seat Cushion fastener
WOW - I would like to here from someone, regarding this post.
07-01-2021, 09:46 AM | #3 |
If I remember, there should be two loops coming off the bottom of the seat spring that go into to holes in the floor pan. I'll be working on my car later today so I'll take a look and get a couple of pictures.
07-01-2021, 08:58 PM | #4 |
Tinbasher
I got an answer from an A owner in MAFCA. I can now see and understand my current situation - I have had my rear seat bottom reupholstered spring devices gone and having new floors welded in, I will now have to invent something new. |
07-02-2021, 07:58 AM | #5 |
Here's what it was like. Might give you a idea. I'll try again later. For some reason the pictures won't upload. JP
09-06-2022, 11:31 AM | #6 |
09-06-2022, 10:08 PM | #7 |
I had to really push on the front of my rumble seat bottom in order to get the loops to drop into the holes.
09-07-2022, 01:36 AM | #8 |
Tim…
Agreed they are a press fit…..they don’t just drop in. |
09-08-2022, 12:50 AM | #9 |
Somebody wallered my holes out. I have been thinking about trying to find rubber grommets to fit in the holes and then the loops in the grommets.
09-08-2022, 06:34 AM | #10 |
Maybe spot weld some large washers that are the same diameter or a piece of sheet metal and drill the right size hole?
Join Date: Mar 2022 Location: Corbin, KY Posts: 34 Default Re: Rumble Seat Cushion fastener Somebody wallered my holes out. I have been thinking about trying to find rubber grommets to fit in the holes and then the loops in the grommets. |
