Old 06-26-2021, 03:18 PM   #1
dlfrisch
dlfrisch's Avatar
Default Rumble Seat
After my total rebuild - what holds the rumble seat bottom cushion in?
dlfrisch is offline   Reply With Quote
Old 06-26-2021, 05:32 PM   #2
springerpete
springerpete's Avatar
Default Re: Rumble Seat
On my '29 roadster there are two holes in the pan under the cushion that should match up with two long " U " loops on the seat spring bottom. I lube both with never seize and crawl under the car and pull the loops down into the pan holes. Before I get under the car I position the cushion as best I can. Back rest goes in next.
springerpete is offline   Reply With Quote
Old 06-26-2021, 05:47 PM   #3
Oldgearz
My Coup rumble seat bottom cushion has two spring loops that stick down and go into holes in the floor. The springs work the same way as the small panel clips on the front door. A used part supplier may be able to help you.
Oldgearz is offline   Reply With Quote
Old 06-26-2021, 05:57 PM   #4
dlfrisch
dlfrisch's Avatar
I will have to investigate the attachment for the rumble seat cushion, when it comes home. The A is getting the new top put on at the canvas top shop. Hope it’s done soon. There is a Model A parade on the 4th, we hope to be in. We live in a medium size gated community and there are 8 or 9 Model A’s living here.
