03-11-2021, 10:23 AM | #1 |
Throttle Position
This is just out of curiosity, but in 3rd at 45 mph on the level with a Tilly, it seems like I have about 75% of the throttle travel left. Is there any easy was to see what the butterfly position really is?
03-11-2021, 12:52 PM | #2 |
Re: Throttle Position
Have you tried setting the hand lever to match the foot position, then look at the throttle shaft position ?
03-11-2021, 01:39 PM | #3 |
Push the clutch in, turn off the key, and coast to a stop. Then get out and look.
03-11-2021, 06:30 PM | #4 |
It does not surprise me. At 45 MPH you are not pushing the cars abilities. Not only that it's a fairly light car.
03-11-2021, 07:46 PM | #5 |
Oh, you said "easy". But since you're curious I'll leave this here. As can be seen, by the graphs, RPM (speed) vs TPS is highly dependent on driving conditions. I will say that based on what I've observed 75% at 45 mph seems about right.
03-12-2021, 12:26 AM | #6 |
03-12-2021, 12:49 AM | #7 | |
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
03-12-2021, 06:12 AM | #8 |
I meant it seems like the throttle is only 25% open, is that what you mean? As a former instrumentation engineer, I salute you on adding the TPS! When I click on the graphs, they are too small to read, can you post the URLs of the images?
03-12-2021, 08:19 AM | #9 |
Because you're just loafing along on level ground not much throttle opening is required. It doesn't take much horse power for that.
03-12-2021, 12:33 PM | #10 |
I think my coupe's non-aerodynamics chews up a good bit of the power when going 45mph on level ground.
Thread Tools | |
Display Modes | |
