08-09-2019, 01:29 PM | #1 |
Rear Axle Messtoration
Among other modifications, the previous owner of my coupe welded lower shock mounts onto the rear axle tubes midway between the banjo and brake backing plates. He used 1/4 inch steel plate that is welded to the tubes around a 180 degree arc. The welds attach the plate along both sides of the plate/tube interface. Nice welding job, but I'm restoring this car and need to remove these.
I am looking at using a 4 inch cutting wheel to remove and a grinding wheel to finish up. Any thoughts or suggestions would be appreciated! |
08-09-2019, 01:37 PM | #2 |
Re: Rear Axle Messtoration
A couple thoughts... Maybe cut the majority off with a torch, and just do clean-up grinding. Or take them to a local welder and let them cut off the excess. They'll probably be good enough with a torch that you'll have just a little grinding to do (definitely true for me that I'd do a %$%##^-y job!). I find folks like that are sympathetic to restorers and don't charge much for their services. And I would assume there's a decent amount of grease and flammable gunk in the housings that you'll have some flames and a ton of stinky smoke!
08-09-2019, 02:20 PM | #3 | |
08-09-2019, 02:30 PM | #4 |
My suggestion would be to try to find some serviceable replacement axle housings.
Tom Endy |
08-09-2019, 03:37 PM | #5 |
I have good housings if you go that direction.
08-09-2019, 04:17 PM | #6 | |
How much heat do you think was there when the brackets were welded on Bob |
08-09-2019, 05:44 PM | #7 |
Brentwood Bob: I do have access to some good housings but would prefer not to dismantle a rear end that was completely rebuilt with new bearings and ring & pinion.
Bob C: Good point about the heat from the welding job. The car did drive straight on the road so the welding must have been done by somebody who knew what they were doing. |
08-09-2019, 05:47 PM | #8 |
Last time I checked, Bill Barlow in Bend had 21 sets of housings for sale.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
08-09-2019, 06:10 PM | #9 |
To me it's not worth to try to cut off the supports . The cutting ,grinding , and the chance of grinding through the axle housing . Save time and just get replacements. It will save time in the long run . I can understand you not wanting to take the housing apart.Best of luck on what ever you choose to do .
08-09-2019, 08:26 PM | #10 |
I would try grinding them off. Its all about finesse. Use a 1/16 or better an 040 cutting wheel. (O40 is a little harder to find at the big box stores.)
I would not worry about any "heat affected zone." The remainder of the axle is plenty strong enough. And while straightness is a concern, it is unlikely welding would have changed the axle housing measurably. Joe K
Shudda kept the horse. |
08-09-2019, 09:17 PM | #11 |
I had the same exact situation. The shock mounts you refer to were sold by J C Whitney back in the sixties. I know because I bought a set and had them installed on my coupe back then. They turned out not to be such a great idea so later I decided to remove them. It was a fairly tedious job but it turned out well. I didn’t use a torch. I used a pneumatic grinding tool to cut away as much of the weld material as possible. I did have to cut away some of the metal strap to free it from the axle. After grinding off the remaining weld it’s hardly noticable
Sent from my iPhone using Tapatalk |
08-10-2019, 10:29 AM | #12 |
Replace the housings! When welded on they distort, putting a strain on axles and wheel bearings. When we weld on race car axle housings, we have to straighten them.
08-10-2019, 11:04 AM | #13 |
I wouldn't assume that the innards were correctly set up with all new parts.
08-10-2019, 11:48 AM | #14 |
I recently removed shock mounts from the axle housings.
Jim, how do I check to see if the housings are warped? |
08-10-2019, 01:21 PM | #15 |
Not Jim but one way to check would be to mount the trumpet end of the housing against a face plate of a lathe and "spin" the housing to check for run-out of the small end.
An acceptable mount match would be the flange of the housing. One could bolt a pumpkin/banjo to the faceplte (check for run-out of pumpkin flange too before adding on) and then mount the trumpet housing to this. A lathe chuck directly to the trumpet flange could do this less accurately. Given the looseness of the Model A differential housing cage/gears (0.010 is target backlash) it would take a considerable amount of warp to condemn a housing. On assembly, one would want to be sure the axle shaft can be held "centered" in the small end of the housing with little or no side pressure (so you don't wipe out the seal at this point.) Joe K
Shudda kept the horse. Last edited by Joe K; 08-10-2019 at 01:27 PM. |
08-10-2019, 02:46 PM | #16 |
A machine shop that is capable of machining the bearing hub can also straighten the housing. I have seen it done. The flange is bolted to a face plate on a lathe, the unit is rotated and the hub end is observed. If it is low the opposite side of the housing is heated with a torch. This procedure is continued around the circumference until the hub end is straight, then it is machined and a replacement race is pressed on with an interference press fit. I have had a number of them done this way.
Tom Endy |
08-10-2019, 04:23 PM | #17 |
Jim is right. Welding on one side of an axle housing will pull it in the direction of the weld. If you weld a bracket on a housing you should continue the weld all the way around,360*. Even then it should be checked.
John
Welcome each day |
08-10-2019, 06:10 PM | #18 |
I had to do the same thing to a Doodle Bug I'm making with an "A" axle, I would cut off what you can with a cut off wheel, the thinner the cutoff wheel the faster it will go, and then use some 40 grit flapper wheels to sand down the remaining. The flapper discs will make quick work of cleaning up the welds, I would think you could get the job done in less than an hour.
Flapper disc, Neiko 11142A, 10 for $17.00 on Amazon |
08-11-2019, 05:27 AM | #19 |
If you are going for a show car, cut them off after the car is drivable. If it’s going to be a driver, leave them on.
08-11-2019, 09:25 AM | #20 | |
