Old 07-27-2016, 02:23 PM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default Model A Bypass Hose
This will act as a bypass hose for now, but these inlet and outlet fittings are for my future hot water heater, which I'll probably mount under the floorboards and use a grate for the heat opening. Even then the heater will still act as a bypass to circulate the coolant in the block until the thermostat opens up. This will give the engine more even heating during the warm up period. I still have to find a couple of clamps for the hose.
Old 07-27-2016, 02:46 PM   #2
Art Newland
Art Newland's Avatar
Default Re: Model A Bypass Hose
I really like this idea, looking forward to seeing your progress. Have you decided what you will use for a heater core?
Art Newland is offline   Reply With Quote
Old 07-27-2016, 04:33 PM   #3
Jim/GA
Jim/GA's Avatar
Tom-
My S/W Town Sedan (originally from Chicago area) had a hot water heater in it when I got it, so it has a thermostat and these same water fittings. It had the "black cube" heater mounted on the inside of the firewall.
It also had a 12 volt water pump mounted under the hood to help circulate the hot water through the core, powered by the same switch that turned the heater blower fan on. I assume the previous owner experimented and determined that the car's water pump was not enough to move the water through the heater, so added the electric pump.
I took the heater and pump out (don't need it in Texas most of the year) to free up space under the gas tank on the passenger side. But I left a heater hose connected between the inlet and the outlet, plus I added a valve to close it off any time I want.
I have a temperature gauge on the engine and I have experimented with running the valve on the bypass hose open and closed, to see if it made any difference. When the valve is closed, the temperature swings up and down quite a bit as the engine is first warming up.
It appears that the coolant trapped in the block by the thermostat gets pretty hot before enough of it makes its way up to the thermostat to open it. Then there is a rush of cool water up into the block and you see the temperature gauge drop back down. The thermostat closes partially or fully. Then the coolant gets hot again. Eventually it settles down to a normal operating temperature.
With the valve open on the bypass hose, the temperature gauge shows the coolant temperature rising slowly and steadily. You don't see the wild temperature swings. I think it is a better way to warm up an engine. I drive with it that way except on the hottest days of the summer, when I don't want any hot water bypassing back into the engine inlet. Then I close the valve.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 07-27-2016, 05:05 PM   #4
CarlG
CarlG's Avatar
Originally Posted by Tom Wesenberg View Post
... I still have to find a couple of clamps for the hose.
Just for kicks, on my new engine, I decided to try some of those Gates shrinkable clamps on the heater lines. Not only do they work, they look good as well.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-27-2016, 06:34 PM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
You guys are killing me with this "hot water heater" stuff!
#warmwaterreheater
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-27-2016, 07:29 PM   #6
Tom Wesenberg
#warmwaterreheater
Well, it couldn't be a heater if it was cold water.
Old 07-27-2016, 07:51 PM   #7
Mitch//pa
Install an inline electric water pump in the heater hose to the core inlet
Old 07-27-2016, 08:58 PM   #8
Tom Wesenberg
The restriction of a thermostat in the top radiator hose should give good flow to the heater. I'll find out when I install the heater. At the last swap meet was an NOS heater core for an older Chevy pickup that I should have bought for $15.
Old 07-27-2016, 09:15 PM   #9
tbirdtbird
Tom, it would be easier to just move to Texas, and shun those harsh winters up there. I can make space for u in my shop. dave
'31 180A
tbirdtbird is offline   Reply With Quote
Old 07-27-2016, 09:25 PM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Talk about HEATERS! It's 109 here today, tomorrow will be 111! Once, I did 39 miles, in town, in BLACK Minerva, on a 112 degree day & she didn't dribble, when I got back.
Bill Hot
"THE ASSISTANT GURU OF STUFF"
Old 07-27-2016, 11:12 PM   #11
DougVieyra
DougVieyra's Avatar
Average High temperature in Eureka - 63 degrees
Average Low temperature in Eureka - 61 degrees
DougVieyra is offline   Reply With Quote
Old 07-27-2016, 11:43 PM   #12
eagle
eagle's Avatar
Bill Hot
Yeah. But its a DRY HEAT, right?
Actually, my A cools so well I'm thinking about bypassing some water out the bottom of my radiator and running it to a heater core....Air conditioning for the summer!
Last winter we had such cold weather... On my way from the house to the shop my coffee froze solid. It froze so fast the ice was hot!
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 07-28-2016, 04:44 AM   #13
Ed Saniewski
Ed Saniewski's Avatar
Brent, was #warmwaterreheater suppose to be a link to something? If so it did not work.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
http://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 07-28-2016, 09:08 AM   #14
Bob Bidonde
Bob Bidonde's Avatar
Tom,
I suspect that the bypass flow is back into the engine because the tap is on the high pressure side of the water pump. If so, hot coolant is flowing back through the engine and displacing lower temperature coolant from the radiator.
I do not know if the volume of bypass flow is enough to cause a deleterious engine temperature rise.
Bob Bidonde
Old 07-28-2016, 09:37 AM   #15
Cool Hand Lurker
Cool Hand Lurker's Avatar
I just looked up those Gates clamps. Another fine use for heat-shrink plastic !
Thanks, Carl
Cool Hand Lurker is offline   Reply With Quote
Old 07-28-2016, 10:25 AM   #16
ddweave
ddweave's Avatar
I guess the downside is you can only use them once. Better keep some regular clamps with you for roadside repairs.
Doug in Waterloo
ddweave is offline   Reply With Quote
Old 07-28-2016, 10:40 AM   #17
CarlG
CarlG's Avatar
That's the very reason I didn't try to use them on the radiator hoses, just the heater hoses.
Alaskan A's
Old 07-28-2016, 11:27 AM   #18
BRENT in 10-uh-C
Google 'Twitter'
BRENT in 10-uh-C
Old 07-28-2016, 04:26 PM   #19
marc hildebrant
marc hildebrant's Avatar
Tom,
Would a valve in the bypass make sense ? You could close it in the summer.
Marc
marc hildebrant is offline   Reply With Quote
Old 07-28-2016, 05:11 PM   #20
Jim/GA
Jim/GA's Avatar
Originally Posted by marc hildebrant View Post
Tom,
Marc
Marc-
I have a valve in mine. I close it in the summer. I want all the cooling I can get out of the radiator in the summer.
I do see the temperatures swing around a bit if I start out with the valve closed, until the thermostat settles down.
Sometimes I start out for the day with the valve open, and then go in and close it on my first rest stop. That's always a good time to look under the hood anyway, for signs of anything being amiss after running for a while.
Jim Cannon
