Old 05-18-2015, 06:09 PM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default An inexpensive engine
This is an inexpensive good little street engine. Why I say inexpensive is when I stripped it I could see it was a low mileage 8BA with a 4in. crank and a EAB cam and .040 bore with very little ring ridge. SO, it would make a good little engine for a 40 coupe that the owner is making out of pieces of 2 cars. Cut the little ridge, honed the cyl, polished the .020-.020 crank, used EAB heads, and a Fenton super dual intake. The owner is going to get one of Babba,s Chevy dist. It runs super on the test stand. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 05-18-2015, 06:31 PM   #2
Thaplumbr
Thaplumbr's Avatar
Default Re: An inexpensive engine
That's a beauty!!!
Thaplumbr is offline   Reply With Quote
Old 05-18-2015, 06:34 PM   #3
ford38v8
ford38v8's Avatar
He's a lucky guy to have found that engine, and he's smart to have brought it to you.
Alan
Old 05-18-2015, 07:04 PM   #4
oldford2
oldford2's Avatar
Walt,
You saved that fellow a lot of $$. Good to find an engine full of nice surprises. Now get it off the test stand before the arm chair test stand police jump on you. LOL
John
oldford2 is offline   Reply With Quote
Old 05-18-2015, 07:08 PM   #5
JSeery
JSeery's Avatar
Believe Walt is part of the test stand police and I'm sure he didn't run it on the test stand for an extended period of time!
Old 05-18-2015, 09:24 PM   #6
41panelmark
41panelmark's Avatar
Very nice Walt.
41panelmark is offline   Reply With Quote
Old 05-19-2015, 09:33 AM   #7
BrianCT
BrianCT's Avatar
Walt, you didn't say if you used new rings, perhaps that was understood?
[FONT=Comic Sans MS]
BrianCT is offline   Reply With Quote
Old 05-19-2015, 12:13 PM   #8
19Fordy
19Fordy's Avatar
Be sure an chrome plate or nickle plate that copper tubing so it looks nicer.
Old 05-19-2015, 12:50 PM   #9
Walt Dupont--Me.
Was I supposed to put rings I it? You expect me to remember everything. Lol Walt
Old 05-19-2015, 03:35 PM   #10
Pete from OZ
Pete from OZ's Avatar
Hello Walt,
Just asking how long do you normally run your rebuild engines on a Test stand.
Thanks
Pete from OZ
Pete from OZ is offline   Reply With Quote
Old 05-19-2015, 05:13 PM   #11
Fredb_
Fredb_'s Avatar
Looks nice Walt!
Fredb_ is offline   Reply With Quote
Old 05-19-2015, 06:48 PM   #12
Walt Dupont--Me.
Originally Posted by Pete from OZ View Post
Hello Walt,
Thanks
Pete from OZ
I've posted this before. It's all common since. Fire the engine, look at oil pressure, if engine is hitting all 8 cyl, speed it up to 16-1800, keep eye on oil pressure and water temp, run engine 15 min, jass the throttle now and then, bring it down to idle, ajust carbs, this shouldn't take long. The idea is don't let a new engine set and idle a long time. I probably don't run an engine on the stand more than 20min or so. Walt
Old 06-10-2015, 10:04 AM   #13
white64
white64's Avatar
Now I have to play a serious game of "catching-up" with walt!
white64 is offline   Reply With Quote
Old 06-10-2015, 01:16 PM   #14
captaintaytay
captaintaytay's Avatar
That's a nice combination Walt, very nice.
Really, I'm Trying
captaintaytay is offline   Reply With Quote
