Old 10-12-2014, 08:28 AM   #1
Phred
Phred's Avatar
Default Brake Drum Retainer
I would like to see some photos, plans, or sources to buy or make safety retainers that would hold the rear drum in place in case the rear axle would break.
Thanks in advance for any help.
Peace
Phred is offline   Reply With Quote
Old 10-12-2014, 02:47 PM   #2
Pete
Pete's Avatar
Default Re: Brake Drum Retainer
Peace
http://www.speedwaymotors.com/Early-...iner,1981.html
This one shows out of stock.
It is the best one though.
http://www.speedwaymotors.com/Garage...Kit,58070.html
Old 10-12-2014, 03:11 PM   #3
quickchange
quickchange's Avatar
Have a spare set of the latter ones that speedway are out of stock ,Early summer in NZ
quickchange is offline   Reply With Quote
Old 10-12-2014, 09:07 PM   #4
glenn in camino
glenn in camino's Avatar
Keep the nut tight and that won't happen
glenn in camino is offline   Reply With Quote
Old 10-12-2014, 09:55 PM   #5
denis4x4
denis4x4's Avatar
Here's a photo of the Speedway retainer. When you break an axle, it makes no difference as to how tight the nut is.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 10-13-2014, 10:32 AM   #6
1931 flamingo
1931 flamingo's Avatar
I think someone on the HAMB is making them or check on the EV8 forum.
Paul in CT
Old 10-13-2018, 12:43 PM   #7
ghalperin
Will these work on mechanical brakes?
ghalperin is offline   Reply With Quote
Old 10-13-2018, 01:00 PM   #8
Charlie Stephens
Peace
What type of brakes do you have? Mechanical? Hydraulic (what year)?
Charlie Stephens
Old 10-13-2018, 04:12 PM   #9
Pete from OZ
Pete from OZ's Avatar
Vern Tardell have them
Pete from OZ is offline   Reply With Quote
Old 10-13-2018, 04:20 PM   #10
Lawrie
Lawrie's Avatar
They mount off the brake wheel cylinder bolts.
Lawrie
Lawrie is offline   Reply With Quote
