08-23-2013, 09:43 PM | #1 |
wipers
Guys,
When I turn on the (vacuum) wiper, it swings to the passenger side and stops. If I pull it back to the drivers side it'll swing back to the pass side again and stop. What do I check? Can I do it on the truck or do I need to remove it from the windshield? Thanks. R / Roger. |
08-23-2013, 09:51 PM | #2 |
Re: wipers
Heres some good info http://modelabasics.com/wiper.htm I just got mine going today. Took it off to figure how to put on the wiper arm. Had some royal purple oil sitting there,so i squirted some in the hole worked arm back and forth full swing. Hooked up to my s10 vacuum line still didnt work so i gave it some more oil. Now it works , think i ordered the wrong wiper blade. Dont see anyway thats going to attach.
08-23-2013, 10:21 PM | #3 |
Re: wipers
Work the rubber on the paddle with some light oil till it's soft, then coat the paddle and chamber with a lubricant. I use Vaseline, but I have also used Vicks Vapo-rub in an emergency, but that's another story. I've never been successful trying to get a wiper to suck lubricant in, but that may just be me and my methods. Make sure all your vacuum connections are tight.
