Old 03-29-2013, 04:54 PM   #1
B0B
Default Spark and Throttle Levers or rods
I bought new Spark and Throttle rods or levers for my 1929 Model A and have run into a problem . I got new springs for these the springs that were on there had been cut roughly in half by a previous owner and they did work . I got the new rods in there ( no easy job) with anti rattle felts on them only to find that the new springs are almost 2 inches long and will not fit ! I compressed one new spring in a vice and it was 3/4 of an inch long fully compressed . Measuring I see there is only 1/2 inch of space for the springs on the rods . SO what is normally done here should I Cut the springs or Drill new rivet holes near the end of the rods ? I could pick up about 1/4 inch by re-drilling? What have you done to solve this problem ?
Also Should there be any washers or other hardware on there or just the springs and little ball ends ? I want to get the Throttle and spark rods or levers on there correctly .
THANK YOU ! B0B in Michigan
B0B is offline   Reply With Quote
Old 03-29-2013, 07:58 PM   #2
Drive Shaft Dave
Default Re: Spark and Throttle Levers or rods
When I put on new springs I got them from Brattons, they were correct in every way. No washers.
Drive Shaft Dave is offline   Reply With Quote
Old 03-30-2013, 01:33 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Are your rods fully against the ripples in the column top?
Here's a picture of my original 1928 7 tooth column, and the springs installed length is a hair over 1". It appears the springs have about 9 1/2 turns each, and from the top of the spring to the points on the rod ends I have about 1 5/8" or a hair more.
Old 03-30-2013, 11:24 PM   #4
Tom Wesenberg
Bob, any update on the spring problem?
Old 03-31-2013, 10:31 AM   #5
Russ/40
Russ/40's Avatar
Did they send you the correct rods? I had to send mine back for a switch to the proper ones.
Old 04-02-2013, 06:49 AM   #6
RockHillWill
RockHillWill's Avatar
Another issue that I have encountered is that the bend radius is much larger on the repos and the rods will not go all the way down into the top bushing. A bushing with the top of the holes tapered will help, but some small grinding on the radius of the rods will help.
Just a thought.
Uncle Bud says "too soon old, too late smart!"
RockHillWill is offline   Reply With Quote
