Old 03-11-2021, 10:23 AM   #1
Bruce of MN
Bruce of MN's Avatar
Default Throttle Position
This is just out of curiosity, but in 3rd at 45 mph on the level with a Tilly, it seems like I have about 75% of the throttle travel left. Is there any easy was to see what the butterfly position really is?
Old 03-11-2021, 12:52 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Throttle Position
Have you tried setting the hand lever to match the foot position, then look at the throttle shaft position ?
Old 03-11-2021, 01:39 PM   #3
Redbird
Redbird's Avatar
Push the clutch in, turn off the key, and coast to a stop. Then get out and look.
Redbird is offline   Reply With Quote
Old 03-11-2021, 06:30 PM   #4
Gene F
Gene F's Avatar
It does not surprise me. At 45 MPH you are not pushing the cars abilities. Not only that it's a fairly light car.
Old 03-11-2021, 07:46 PM   #5
MALAK
MALAK's Avatar
Oh, you said "easy". But since you're curious I'll leave this here. As can be seen, by the graphs, RPM (speed) vs TPS is highly dependent on driving conditions. I will say that based on what I've observed 75% at 45 mph seems about right.
MALAK is offline   Reply With Quote
Old 03-12-2021, 12:26 AM   #6
old31
What is that thing over the carb?
old31 is offline   Reply With Quote
Old 03-12-2021, 12:49 AM   #7
JayJay
OK, I'll stick my neck out and ask - what in the world possessed you to put a throttle position sensor on a Zenith carb? Was there something specific or just a cool thing to do? That is indeed a most elegant installation!
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 03-12-2021, 06:12 AM   #8
Bruce of MN
I meant it seems like the throttle is only 25% open, is that what you mean? As a former instrumentation engineer, I salute you on adding the TPS! When I click on the graphs, they are too small to read, can you post the URLs of the images?
Old 03-12-2021, 08:19 AM   #9
Patrick L.
Patrick L.'s Avatar
Because you're just loafing along on level ground not much throttle opening is required. It doesn't take much horse power for that.
Old 03-12-2021, 12:33 PM   #10
Bruce of MN
I think my coupe's non-aerodynamics chews up a good bit of the power when going 45mph on level ground.
