Old 03-30-2018, 12:31 PM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default Irontite sealer?
I have a small amount of water coming out the the left side header where it mates to the header extension. Am going to use NEVER SEIZE in the header bolts and RTV around the gasket between header and extension. Am wonder if the IRONTITE CERAMIC MOTOR SEAL might be a good idea also, anybody use this product?
36tudordeluxe is offline   Reply With Quote
Old 03-31-2018, 01:50 AM   #2
hardtimes
hardtimes's Avatar
Default Re: Irontite sealer?
In fact, I have used 'liquid glass' aka Ceramic seal.
Follow the directions exactly !
Worked well for me. Does not mix with anti freeze, so flush engine with clean water, heat it up and put it in, pursuant of maker instructions.
If you try it , let us know how you get along.
Old 03-31-2018, 09:42 AM   #3
Ronnie
Ronnie's Avatar
Here is a easy item to try they have been used for years.
http://www.acdelco.com/auto-parts/ve...seal-tabs.html
Ronnie is offline   Reply With Quote
Old 03-31-2018, 06:21 PM   #4
AnthonyG
AnthonyG's Avatar
This stuff works pretty good.
https://www.toolsource.com/misc-c-31...MaAtwrEALw_wcB I had 1 head bolt weeping coolant and saw a bit of vapor on the same side on exhaust. Put this stuff in per instructions and it stopped the leak and the vapor. Almost 2 years. Removed coolant as I do normally annually still no leak not vapor.
Nomad
AnthonyG is offline   Reply With Quote
Old 03-31-2018, 06:26 PM   #5
petehoovie
petehoovie's Avatar
K-SEAL
Old 03-31-2018, 09:14 PM   #6
wga
wga's Avatar
36 -- used Irontite with excellent results. Tried the usual stuff on the shelves - Barrs Leak, Barrs aluminum / copper, they did not seal the leak.
Just get your block super clean, all traces of anti freeze should be gone. I used the Irontite cleaner, ran it for hours. Also used a dishwasher detergent pod, rinsed and back flushed. Mixed the Irontite in a bucket and added it along with water to the cooling system. Ran it for hours. Drained the cooling system. Irontite needs to dry/cure to be fully effective. I removed the thermostat housings (8BA) and lower radiator hoses. Let it sit for about a week. Filled it with bottled water and water wetter (2 bottles). Just follow their directions, and you'll be pleased with the results.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 04-01-2018, 04:48 AM   #7
Yoyodyne
Yoyodyne's Avatar
K-SEAL
+1 for this. Worked for me in a Mitsubishi fork lift engine after sodium silicate didn't.
Yoyodyne is offline   Reply With Quote
Old 04-01-2018, 09:20 AM   #8
sidevalve8ba
sidevalve8ba's Avatar
I've had good luck with this stuff, too.
sidevalve8ba is offline   Reply With Quote
Old 04-01-2018, 11:25 AM   #9
Jack E/NJ
Jack E/NJ's Avatar
36tudordeluxe>>>I have a small amount of water>>>
I find that small leaks like this disappear after about 500 miles or so with nothing but regular name-brand 50-50 glycol anti-freeze. Jack E/NJ
Old 04-01-2018, 11:26 AM   #10
36tudordeluxe
Got the Irontite sealer and cleaner on order, will post results. Thanks everyone for the advice.
Old 04-06-2018, 07:35 PM   #11
36tudordeluxe
No more leaking water out the lower header bolt near cylinder # 8. First ran in header bolt with NEVER SEIZE and used RTV where header and header extension meet, that stopped leak right there. Next used IRONTITE FLUSH and back flushed the system, then flushed with tap water and then added IRONTITE WEATHER SEALER and coolant. No leak, but wonder where that water was coming from.
Thanks everyone for the help.
Old 04-07-2018, 12:29 PM   #12
cmbrucew
cmbrucew's Avatar
Has anyone used this product?
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
