Old 01-15-2022, 09:21 PM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default Resizing rods
I’ve resized a set of 8ba rods for my new rebuild. Question is, I’ve got two rods that are within specs vertical, and at like 2and 8 and at 10 and 4 but .003 out at the parting line with the rod and cap. Is this gonna be a problem ?
Old 01-16-2022, 08:40 AM   #2
cadillac512
cadillac512's Avatar
Default Re: Resizing rods
No problem. Resized rods are commonly a bit above spec at the parting line and work fine. We resize rods every day (engine rebuilding shop) and this is normal.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 01-16-2022, 12:58 PM   #3
35fordtn
35fordtn's Avatar
Ken this is normal for what I have used as well.
Old 01-16-2022, 02:06 PM   #4
JWL
I crush the rod sides before cutting the cap and honing when they are OS at the part. The bearing is only held in place by the press fit in that bore. Maybe those will be ok?
JWL is offline   Reply With Quote
Old 01-20-2022, 03:29 PM   #5
Dan McEachern
You can also suck in the parting line by angle grinding the parting line slightly. Putting a .002" feeler under one side when grinding the opposite side will pull the parting line in when the caps are torqued in place.
Dan McEachern is offline   Reply With Quote
Old 01-20-2022, 11:16 PM   #6
Karl Wolf
Karl Wolf's Avatar
I started working in an automotive machine shop when I was teen.
This was one of the first things that I learned, did.
I don't think I would do it now, unless the rods were very worn.
Karl
Karl Wolf is offline   Reply With Quote
