07-06-2018, 02:46 PM | #1 |
Valve seat crack????
How are valve seats cracks repaired? Have a early engine with 1 cracked valve seat, the crack goes to the edge of the cylinder. Are these normally welded? The crack does not go down into the cylinder. I do not have the valve out. It is a 36LB engine, thanks
07-06-2018, 04:14 PM | #2 |
Re: Valve seat crack????
Most machine shops pin them with Irontite cast iron threaded taper pins or Lock & Stitch methods. Cast can be welded but it takes a lot of heat to fusion weld a block. This is a specialty trade and they mostly work on unobtanium type antique stuff. Most shops recommend a sleeve to reinforce a cylinder wall that is on a repaired area due to warranty possibilities. This link to You-Tube gives some info. https://www.youtube.com/watch?v=Y7dDZgflHKw
07-07-2018, 06:58 AM | #3 |
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
