Old 11-25-2015, 11:06 AM   #1
rossodino34
rossodino34's Avatar
Default 1940 Station Wagon outer door handle spring Help!
I have a 1940 Deluxe Station Wagon (woodie). The driver side rear, outside door handle spring broke. It has proven to be a part that is used only on this model and year only. Although it may also be compatible with 1939 wagons and '39 and '40 convertibles.
From what I have determined there are no reproductions manufactured. I had my hopes pinned on a collector that thought he had one but we struck out. in fact he just had a spring fail on his 1939 convertible and is faced with the same dilemma.
Does any one know of where to find a used or NOS spring or ideas about another version that may work?
rossodino34 is offline   Reply With Quote
Old 11-25-2015, 11:26 AM   #2
Bill
Bill's Avatar
Default Re: 1940 Station Wagon outer door handle spring Help!
Try RPM he has visited you public profile page. He has accumulated a pile of 40 wagon parts. Twist his arm a little as woodie people tend to hoard their stuff...Good luck. Bill
Bill is offline   Reply With Quote
Old 11-25-2015, 11:40 AM   #3
deuce_roadster
deuce_roadster's Avatar
You may have better luck buying a complete latch. I rebuilt one for a friend and if you have a lathe to make special rivets It isn't too hard. There is no spring in the handle, it is within the latch itself.
Old 11-25-2015, 12:23 PM   #4
woodiewagon46
I had the same issue with one of the handles on my '46 Wagon. I found the spring at Job Lot in Queens. I understand they have closed or are in the process of closing. They had a box about 18"x 12" with dozens of springs. If you can call them and they are still open you may be in luck. Try an old time shop that may have the same box of springs.
woodiewagon46 is offline   Reply With Quote
Old 11-25-2015, 12:40 PM   #5
woodiewagon46
Ross, I just checked and when I went to Job Lot I purchased extras. If '40 and '46 is the same I have one for you. Is there any way to post a tracing of your spring so we can match it? I am computer illiterate, so I don't know how to do it. You can also contact me at [email protected] if that is easier.
Old 11-25-2015, 02:37 PM   #6
alan
I also have a box of NOS door springs and have helped others by them sending me a pencil tracing of the broken spring. I have a 40 wagon also
alan is offline   Reply With Quote
Old 11-25-2015, 09:12 PM   #7
rossodino34
Here is an image of the spring. It broke at the point where it exits the mount located in the center of the "coil".
Hopefully this helps. I am waiting for the collector that thought he had one in his inventory to send my original back to me.
Old 11-25-2015, 09:18 PM   #8
rossodino34
I exploded the image. Hopefully this will be helpful
Old 11-25-2015, 09:28 PM   #9
deuce_roadster
That looks like a very common spring. PM me if you can't find one. If you take it apart, replace the rubber bumper in there.
Old 11-25-2015, 09:30 PM   #10
rossodino34
I hope Job Lot is not closing. I have used them for years and they have always been very knowledgeable and helpful. If I give them a part number they either have it or know who should have it. I am going to call them to see whats up. That said any help will be appreciated. I sent pictures in separate posts. The inoperable door concept is getting old.
Old 11-25-2015, 09:34 PM   #11
rossodino34
Deuce_Roadster,
It does look common but I have been told the "look a-likes" do not work.
Old 11-25-2015, 11:29 PM   #12
deuce_roadster
I have a 40 wagon myself, pictures in my public albums. I might have that spring, will look.
Old 11-26-2015, 11:05 AM   #13
woodiewagon46
Ross, I think I have it. If you E-Mail me with your address I can get it in the mail. Yes, unfortunately, Job Lot is closing. I have also used them for years and they always had what I needed, most of the tome NOS parts. I could be at their place in half an hour, very convenient.
