Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 01-19-2019, 07:44 PM   #1
Rick Thompson
Default 1940 Ford Brakes
I am rebuilding the Brake Cylinders on my 40 Ford.
I do not drive the 40 very often and the Brake Cylinder Pistons seize up.
My question is: A) Can silicone grease be applied to the pistons without causing any issues/harm? B) Can a DOT5 Brake Fluid be used to replace a DOT3 Brake Fluid in the 1940 Ford without causing any negative issues? C) Would using a DOT5 Brake Fluid be a solution to reduce Brake Cylinder Piston seize up?
THANKS !!!
Rick Thompson is offline   Reply With Quote
Old 01-19-2019, 09:02 PM   #2
Charlie Stephens
Default Re: 1940 Ford Brakes
You posted in a forum used for questions "To The Editors". Very few people read this (except the editors) and even fewer respond. You should post here: https://www.fordbarn.com/forum/forumdisplay.php?f=4
Welcome to fordbarn.
Charlie Stephens
Old 01-19-2019, 10:08 PM   #3
Rick Thompson
Thanks for the heads up.
I am new to this site so I will try your suggestion.
THANKS
