11-10-2020, 11:46 AM | #1 |
gas gauge bail threads
Good morning, folks. Question about 1930 CCPU.
The bail to my gas gauge has broken off at the back of the swinging body. I pulled the bail out of the tank with a pair of needle nose pliers and there are maybe 2-3 threads left. So I'm going to have to pull the gauge and likely drill out and rethread both the body and the bail. I'm wondering if anyone knows the proper thread. Measuring the bail I get a wire diameter of 0.0962", which corresponds most closely to a #3 screw (0.0942"-0.0983"). Pretty hard to tell with just a couple of threads left (and my "mature" eyes) but it looks like it could be 48 tpi, which leads me to conclude that a 3-48 (NC) would be the appropriate pitch. That's not one I've run across before so I don't have that tap set and die in my collection, but before I ordered one I thought I'd see if this august body has any additional thoughts. Yeah, I know I could just order a replacement gauge, but what's the fun in that? BTW, when I pulled the bail out the float was just pushed on and soaked clear through with fuel. No end washer or retention. Looks like a champagne cork with the head cut off. So it's been replaced at least once before, and likely before the era of ethanol fuel. I've ordered a gauge rebuild kit with neoprene float. Thanks all, and stay healthy. JayJay |
11-11-2020, 11:48 AM | #2 |
Re: gas gauge bail threads
I would suspect that the thread on the bail is a rolled thread, so it would be slightly larger than the wire size. maybe #4? 4-48?
11-11-2020, 01:20 PM | #3 |
Use the BRASS float, like inside the carburetor Henry used brass there.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
11-11-2020, 06:36 PM | #4 | |
Katy - good thought, thanks. It looks like a cut thread to me, and when I mic'ed it over the threads it showed 0.092"-0.093". Major diameter of a #4 is 0.112". Regardless, since I've ordered a set of compatible #3-48 taps and dies, that's what I think I'll use and say to heck with it (although that is really an oddball thread - never run into it before). Kind of reminds me of the time I needed a lock screw for an old Starrett caliper, turns out that was a #5-40. Another new one for me. I'll use the neoprene float for now, and order a brass one. Where do you get those? Scavenge a carburettor? JayJay |
11-11-2020, 07:29 PM | #5 |
Reenlee Kotas in San Diego has really nice brass floats. He advertises in the San Diego Model A Club news letter (The Quail Call). https://www.sandiegomodelaclub.com/the-quail-call
11-11-2020, 08:26 PM | #6 |
He has the kits, tools and floats... Get the better quality tools....and the cork gasket sets seem to work best. https://www.mikes-afordable.com/category/1067.html
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
11-12-2020, 09:12 AM | #7 |
Permatex #3 on the cork. Brass float for sure.
11-12-2020, 10:51 AM | #8 | |
11-12-2020, 02:55 PM | #9 |
Instead of buying taps and dies (which you'll probably only use once) why not just buy a replacement assy??
Paul in CT |
11-12-2020, 10:32 PM | #10 |
I have a few hundred original fuel gauges with good threads, all available very reasonably priced $20 for a complete original gauge, if that helps your cause..
11-13-2020, 04:37 PM | #11 | |
Paul - a very reasonable question. There are several answers.
Thanks for the thoughts. JayJay |
11-13-2020, 04:39 PM | #12 | |
Thanks, Steve, I have the taps and die in hand. If I can't fix it I'll give you a shout. Nice to know (in this day of no swap meets) that there's a backup. JayJay |
07-03-2022, 02:36 PM | #13 |
Sir do you have original gauge for 29/29 model and if so I would like to purchase one
07-03-2022, 02:49 PM | #14 | |
Give Steve a call at Bert's 800-321-1931, they are closed Sunday and Monday. https://modelastore.com/ |
