11-09-2020, 11:37 PM | #1 |
Pictures and description of connecting shifter to transmission - F/M rod
I can’t seem to find any clear pictures or instructions for connecting the shifter to transmission rod for Fordomatic. For starters, does the pin on the end of the rod go through the hole in the direction of the arrow or through the hole toward the arrowhead?
11-10-2020, 06:50 AM | #2 |
Re: Pictures and description of connecting shifter to transmission - F/M rod
Here you go -
***** - DISCLAIMER -
The above posted information is in my opinion only (IMO) and may contain copy and paste material(s). In addition, any above tech information is supplied in good faith. No responsibility implied or otherwise can be accepted for the way others use or interpret provided data. Your experience(s), opinion(s) and mileage may vary. DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
11-10-2020, 08:39 AM | #3 |
without crawling under to verify which way I doubt it can go any way but one.from out in
11-10-2020, 06:13 PM | #4 |
Thanks. That’s the best picture I’ve seen. The good news is I put the rod in correctly on the transmission lever. The bad news is it appears to be too long and it was so tight to get it in (I had to force it in between the lever and footwell, so now doubt I can get it back out. If I can find room to hammer a dent in the footwell, I might be able to get it out.
I think the previous owner changed the length to fit a non-T-bird transmission. I now have a transmission from a 1956 T-bird. One other question. When looking straight at the levers, what is the orientation of the different gear positions? From left to right, Low - 2 - Drive - Neutral - Reverse - Park? |
11-10-2020, 07:28 PM | #5 | |
There is no " 2 " position on the shifter for a '55/'57 T-Bird automatic transmission, P R N Df Lo only. . Last edited by dmsfrr; 11-10-2020 at 08:56 PM. |
11-10-2020, 08:43 PM | #6 |
Thread Tools | |
Display Modes | |
