04-26-2011, 06:19 PM | #1 |
Light rod and switch
So I am finaly assembling my light switch rod and switch my question is how far out of the steering collum is it supposed to stick out because it really dosent look like mine sticks out much. second when the swich rod is in the steering wheel dose the liver point streight down twords me when sitting in the car when all things are off and lastley at the bottom the thingy that goes on the rod is that supposed to be vertical or horizontal. mabe some one can post some pictures so I can visuralize it.
04-26-2011, 07:26 PM | #2 |
Re: Light rod and switch
The switch is straight down when off. The fork at the bottom of the rod should be vertical.
04-26-2011, 07:52 PM | #3 |
thanks
04-26-2011, 07:53 PM | #4 |
You may have a rod that is too short.I am not that familiar with 28-29 stuff,but I ran into a problem a couple of years ago with one.I think the 28 was 45-3/4,and the 29 was 45.If you are using the shaft you got from me that one was pulled from a 28 Special Coupe originally.BUT,who knows if it ever was changed in the 70 years before we got to it?
04-26-2011, 08:13 PM | #5 |
well i am useing the shaft i got from you and I was told there was two sizes I asked for the longer of the two witch is 3/4 longer than the short one I think its the right one but its hard to tell unill i actualy install it.
04-26-2011, 08:48 PM | #6 |
04-27-2011, 11:12 AM | #7 |
she seems prity good theres very little play in the box itself maby an inch on the wheel and i think i just need to take a few shims out and it will be perfect. but now im looking at the rest of my steering assembly thinking o boy i need to redo that to soon.
04-27-2011, 12:01 PM | #8 |
I just finished rebuilding, painting & installing a 7 tooth box in my 60B fordor. Installing the spider on the shaft is almost a two man job. When compressing the spring to install the "C" clip the rod wants to push up the column. I never have anyone around to help so what I did was to install a couple of tie raps around the top of the rod & around a couple of spokes of the steering wheel. This kept the horn rod from moving up. Also your fingers can get sore from pushing on the spider to compress & hold the spring. A couple pieces of small diameter rubber tubing placed over the tabs will save your fingers. Two people make the job easier though. Brattons sell a tool for $7 to push on the spider to compress the spring.
04-27-2011, 12:08 PM | #9 |
04-27-2011, 12:09 PM | #10 |
04-27-2011, 03:05 PM | #11 |
A plastic zip tie works well to hold the horn rod in place while you put the clip on the bottom end.
Just run the zip tie over the horn rod / light switch lever at the steering wheel and run the zip tie over to the back side of the steering wheel and zip it tight. Works great! |
04-27-2011, 04:16 PM | #12 |
i never event thought about the horn rod pushing up ha still the question that hasent been answard is hhow far out of the bottom of the shaft dose the tip of the rod come. an inch an inch and a half? less? more?
04-27-2011, 05:51 PM | #13 |
I have a nice spare early 1929 7 tooth steering column and from the end of the cup that supports the light switch to the end of the horn contact is 9/16". That's as close as I could measure with my tape measure.
