10-14-2012, 12:17 PM | #1 |
Tool Size?
Can someone tell me what size tool i can buy to take the main bearing square nuts off? (socket) I have a bad center main shot. Thanks RAY
10-14-2012, 12:36 PM | #2 |
Re: Tool Size?
the square heads of the front and center main bearing bolts are 9/16". You need a 9/16 eight point socket wrench.
10-14-2012, 12:38 PM | #3 |
Re: Tool Size?
I used an 11/16" 6 pt. impact socket
"no one knows more than everyone" |
10-14-2012, 12:54 PM | #4 |
Re: Tool Size?
I just hold the bolt and unscrew the nut, which is 3/4". This is easier, and more critical when tightening the mains as tightening the bolt has a lot of friction so you don't get a true torque measurement or feel.
10-14-2012, 02:26 PM | #5 |
Re: Tool Size?
21/32" Is the proper size. As others say they work with other sizes..
www.whidbeymodelaclub.com |
10-14-2012, 03:29 PM | #6 |
Re: Tool Size?
10-14-2012, 03:39 PM | #7 |
Re: Tool Size?
There is a "special" tool, many times it can be found in the 1$ box under the table at fleamarkets.
Also there is a small point on one of the corners of the square, it is so you know the location of cotter hole at the other end. |
10-14-2012, 06:58 PM | #8 |
Re: Tool Size?
Thanks guys Appreciate it
10-14-2012, 07:15 PM | #9 |
Re: Tool Size?
21/32 is for the rods.
10-14-2012, 10:31 PM | #10 |
Re: Tool Size?
10-15-2012, 12:37 PM | #11 | |
Location: Sebastopol, CA (Sonoma Co.-Home of Sonoma Model A's)...Come see Snoopy, Luther Burbank, Taste wine/
Re: Tool Size?
For the Flea Mkt. tool, what is the socket configuration & size: Square, 6-pt, 8-pt? 9/16, 21/32, 11/16, other? Both ends the same? Harold Parizek |
10-15-2012, 05:13 PM | #12 |
Re: Tool Size?
9/16 eight point. I get mine at Sears.
