Old 08-22-2013, 08:46 PM   #1
Chris in WNC
Chris in WNC's Avatar
Default goofy question, only slightly Model A related.....
I have a tall aerosol can of WD-40 that is almost full but refuses to spray.
Tried a different nozzle from a working can, no dice with it either, so the malfunction is in the can itself.
Now comes the totally stupid part:
Being a thrifty guy, I hate to chuck a full can of WD-40.
Is it possible to open this can and remove the contents WITHOUT great bodily harm or loosing most of the contents in the process?
I guess I really do have too much time on my hands, but I eagerly await your input on this........
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 08-22-2013, 08:49 PM   #2
Mitch//pa
Default Re: goofy question, only slightly Model A related.....
A.. return it to lowes or home depot for another. no receipt needed
B.. or call the comp direct
Old 08-22-2013, 09:09 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I have a blow gun with a rubber tip and I put it up to the spay nozzle and push the spray nozzle down at the same time I blow air in the can. I never use more than about 60 pounds pressure for this and it has worked for me. I've had the same problem with spray cans of WD-40. I also have a small bottle with a brush that I fill with WD-40. I used a scatch awl to poke a hole on the side of the can near the top. You can also fill a plastic spray bottle, such as an empty Windex bottle.
Old 08-22-2013, 09:17 PM   #4
28ACoupe
28ACoupe's Avatar
Throw it away and go get some PB Blast, Liquid Wrench, or other such.
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
Old 08-22-2013, 09:26 PM   #5
Tom Wesenberg
I wouldn't throw it away.
It isn't the best to use as a penetrating oil or as a lubricant, but WD-40 does work good to prevent rust and corrosion, it removes sticky goo, such as left behind by price stickers, and it makes a good hand cleaner if you don't have Goop handy.
WD-40 also works great as a lubricant when tapping threads into aluminum.
Old 08-22-2013, 09:35 PM   #6
Mitch//pa
and many other uses such as displaces moisture from wet ignition systems
Old 08-22-2013, 09:58 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
I have used another can that is empty but still has pressure and connected them with the little spray tube to transfer some of the pressure
Old 08-22-2013, 10:01 PM   #8
31 Woody
31 Woody's Avatar
If you try any fixes to the can, wear some sort of safety protection for your eyes and lungs just in case.
31 Woody is offline   Reply With Quote
Old 08-22-2013, 11:40 PM   #9
QGolden
QGolden's Avatar
Freeze the can in your home freezer. The internal pressure will drop. If you can dent the can with your thumb, you can punch a hole in it. I have done several. I like to apply WD40 with an Acid Brush sometimes. I keep some in a small canning jar.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 08-23-2013, 07:04 AM   #10
Terry, NJ
Terry, NJ's Avatar
This isn't a "goofy" question! I have two cans with the same problem. I took the nozzle off and place the little white tip on whatever it is I want to loosen and push. In some ways this is better, you don't get so much at once. It's more controllable.
Terry
Terry, NJ is offline   Reply With Quote
Old 08-23-2013, 07:32 AM   #11
spdway1
spdway1's Avatar
Yes!
spdway1 is offline   Reply With Quote
Old 08-23-2013, 07:40 AM   #12
Chris in WNC
Thanks everyone for the great responses.
I was going to take Mitch's advice and return it to Lowe's, but when I went down to the basement garage and got the can the miserable thing actually WORKED!
This is after consistently refusing to work over a period of several weeks. Go figure.
At least I know what to do next time.
I particularly like the freezer solution, and don't worry I will definitely have safety glasses, long sleeves and gloves on before trying to do anything invasive........
Old 08-23-2013, 08:27 AM   #13
QGolden
QGolden's Avatar
I discovered the "Freezer method" after leaving a can in an unheated Tractor Shed. It was winter and had been around zero for a week. I needed to start the tractor and when it was real cold the throttle shaft would get stiff and i was afraid of breaking it, so I would give it a shot of the 40 first. One day I left the can in the shed, and when i picked it up to use it next time it actually had a vacuum in it and sucked air in when i pushed the button! I brought the can in the house and next day it was back to pressure. I then put it in the Freezer and the pressure dropped again. So the propellent is very sensitive to temperature, and it contracts when cold. I have done this with Silicone Spray as well and keep some of that in a canning jar for brush application. I like the stuff but don't want it sprayed on other parts.
Old 08-23-2013, 10:45 AM   #14
Harold frm Sebastopol
Harold frm Sebastopol's Avatar
Location: Sebastopol, CA (Sonoma Co.-Home of Sonoma Model A's)...Come see Snoopy, Luther Burbank, Taste wine/
This was interesting! More "goofy" questions anyone?
Harold frm Sebastopol is offline   Reply With Quote
Old 08-23-2013, 10:51 AM   #15
Jim Brierley
I add air like Tom W. does. If you can't fix it with WD-40, duct tape or a hammer, you have an electrical problem!
Jim Brierley is offline   Reply With Quote
