Old 11-06-2019, 12:02 PM   #1
DelPercio
Default Update on transmission plug
I haven’t updated my original post because my car is 100 miles from my house. I cleaned the plug and with a little muscle and a very large adjustable I got it off. The case isn’t cracked but the oil came out very dirty compared to the rear which looked clean. My question is I was thinking of filling it with transmission fluid and take it for a ride then drain it as soon as I got back. Good or bad idea.
DelPercio is offline   Reply With Quote
Old 11-06-2019, 12:16 PM   #2
WHN
Default Re: Update on transmission plug
Transmission fluid?
600w transmission oil needed. I use half STP and half 600w oil from suppliers.
I would leave plug out and let drain for a couple of days before refilling with new oil.
WHN is offline   Reply With Quote
Old 11-06-2019, 12:40 PM   #3
J Franklin
J Franklin's Avatar
If you want to flush it out with thin oil rather than gear lub, I think it would be better to jack up a rear wheel and don't add the load of driving it on the road. Or you can remove a few bolts and do a thorough clean from the top. This will give you an opportunity to do a visual inspection.
Old 11-06-2019, 01:13 PM   #4
Gary WA
Gary WA's Avatar
With plug out, take air hose with plastic/vinyl hose insert in oil fill area and try to blow out more oil,better to pull pan and clean , also valve cover area cleaning.
www.whidbeymodelaclub.com
Old 11-06-2019, 01:19 PM   #5
ryanheacox
ryanheacox's Avatar
FWIW, Ford recommended flushing with Kerosene.
ryanheacox is offline   Reply With Quote
Old 11-06-2019, 02:14 PM   #6
DelPercio
I can do kerosene and just ride it up the block and back. The car has 3200 miles and maybe the owner couldn’t get the bolt off because the rear oil was almost clear and the transmission was very dirty.
Old 11-06-2019, 02:24 PM   #7
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Just use the kerosene and then fill with new 600 oil. Put a new plug in that fits and seals.
Jacksonlll is offline   Reply With Quote
Old 11-06-2019, 02:34 PM   #8
The Master Cylinder
The Master Cylinder's Avatar
Originally Posted by Gary WA View Post
With plug out, take air hose with plastic/vinyl hose insert in oil fill area and try to blow out more oil, better to pull pan and clean , also valve cover area cleaning.
Pull pan? On the transmission?? Valve cover??
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 11-06-2019, 02:43 PM   #9
ryanheacox
ryanheacox's Avatar
As Jack says. Just fill with Kerosene and drain, maybe rock the car to slosh it if you want. I wouldn't drive it any distance without 600W in it. Also, when you say dirty what exactly do you mean? The 600W that Brattons sells is dark brown right out of the container.
Old 11-06-2019, 03:17 PM   #10
J Franklin
J Franklin's Avatar
Post #3 is a safe thorough way to use kerosene. you only need to run it a short while and by running it, it will flush out the bearings in the cluster as well as splashing it all around the case and tower parts.
Old 11-06-2019, 03:23 PM   #11
Blue-Truck-Nut
Blue-Truck-Nut's Avatar
Never knew Ford recommended Kerosene. I've used Diesel in the past.
Sent from my E6810 using Tapatalk
Blue-Truck-Nut is offline   Reply With Quote
Old 11-06-2019, 07:07 PM   #12
CWPASADENA
CWPASADENA's Avatar
Actually, in the day, Kerosene was a lot more common than Diesel.
Both will do the job just fine.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 11-06-2019, 07:14 PM   #13
Blue-Truck-Nut
Chris W.
Agreed. Funny how that has reversed in current times.
Old 11-06-2019, 07:41 PM   #14
butch chase
use care flushing with thin fluids. when I did it with motor oil, the oil migrated out the input shaft and made a mess on the pressure plate andclutch.
butch chase is offline   Reply With Quote
Old 11-06-2019, 08:02 PM   #15
DelPercio
Thanks for the suggestions. I think I’ll fill it with kerosene, shift through the gears and drain it.
Old 11-06-2019, 10:30 PM   #16
California Travieso
Send a message via Yahoo to California Travieso
Ryan,
Years ago, we visited my wife’s friend in Mexico City. I went with her husband when he was getting an oil and transmission fluid change.
That’s what they did. Filled both with kerosene and rocked the car back and forth then drained the kerosene and filled it with oil and transmission fluid. I think it would be ok to do that with the transmission but I’m not sure I would do that with the engine oil.
David Serrano
California Travieso is offline   Reply With Quote
Old 11-06-2019, 11:14 PM   #17
Gary WA
Gary WA's Avatar
Ha miss read question !!!! You caught me! My mistake for the year!!!
Old 11-07-2019, 09:20 AM   #18
Redbird
Redbird's Avatar
Get a spray bottle and fill with diesel. Spray thru the fill oil and drain out the bottom. I did it to both tranny and rear end when I got my car. The rear end had never been drained since new.
Redbird is offline   Reply With Quote
Old 11-07-2019, 09:23 AM   #19
30 Closed Cab PU
Originally Posted by California Travieso View Post
Ryan,
David Serrano
Am no expert, but agree. When draining motor oil pan, some kerosene would probably get left in the dipper tray?
30 Closed Cab PU is offline   Reply With Quote
Old 11-07-2019, 12:21 PM   #20
captndan
captndan's Avatar
It is not a good idea to use STP or Lucas. The high speed gears will fling it out onto the housing. That’s where it stays effectively reducing the amount of oil in the transmission. Stay with 600W oil.
captndan is offline   Reply With Quote
