08-19-2012, 06:37 PM | #1 |
Using a vacuum gauge
I have been reading in the Les Andrews troubleshooting book that a lot of information can be gathered by using a vacuum gauge. My 28 doesn’t have a vacuum fitting. Is there a way to connect a gauge without drilling the manifold? I am hesitant to drill and spoil the originality of my manifold.
Thanks, Supergant |
08-19-2012, 08:25 PM | #2 | |
Re: Using a vacuum gauge
08-19-2012, 09:32 PM | #3 |
Three companies made adapters, about 1/4" thick, that went between the carb and manifold. You used two gaskets and sandwiched the thing between the carb and manifold, using longer bolts. Ampco oilers, Marvel inverse oilers, and Stewart Warner Southwind heaters all used them for providing a vacuum source. I see them at swaps occasionally. You can make one pretty easy, too.
08-20-2012, 01:55 PM | #4 |
Thanks again, Supergnat |
