Old 11-10-2011, 05:48 PM   #1
Pepsi Mechanic
Pepsi Mechanic's Avatar
Default Need advice in storing our AA Pepsi Truck
It is time for us to store the 28 AA Pepsi truck ... I will be keeping her outside in the enclosed auto hauler trailer .. I have her fueled up ... I have the trickle charger ready to plug in ( will do a trickle every 2 weeks or so ) .. The trailer is not heated ... I am leaving the roof vent open to alow any warm air out ( if there is any this winter ) .. Incase of a major storm we will move the unit in our garage for a day or two ...Is there anything else I should do ? Below is the the truck and trailer
Pepsi Mechanic is offline   Reply With Quote
Old 11-10-2011, 06:17 PM   #2
peters180a/170b
peters180a/170b's Avatar
Default Re: Need advice in storing our AA Pepsi Truck
Move it to a COKE "A" COLA plant for safe keeping....
peters180a/170b is offline   Reply With Quote
Old 11-10-2011, 06:22 PM   #3
Pepsi Mechanic
funny man ... funny man good one though
Old 11-10-2011, 07:02 PM   #4
Brian T
Brian T's Avatar
Hello Harry,
She could always winter here in San Diego with Maggie, (assuming it is a she of course) , if not there could be a lot of little yellow pickup pups running around.
Maybe better to take the battery out and keep in the shop, did you add some additive to the tank?, ..... stay warm Harry.
Brian.
Brian T is offline   Reply With Quote
Old 11-10-2011, 07:14 PM   #5
Dave Boyer
Don't forget to put some stabilzer in the gas. I'd close the roof vent of the trailer, you don't want any heavy snow to break it. I have a friend that stores his Boss 429 in a trailer all winter, sealed up tight, with no issues.
Love your truck, I guess I've missed it, I've never seen it until today.
Dave Boyer is offline   Reply With Quote
Old 11-10-2011, 07:45 PM   #6
Pepsi Mechanic
Originally Posted by Brian T View Post
Hello Harry,
Brian.
Hey Brian .. Thats funny .as long as the pups like Pepsi that could work .. I put some stablelizer in the tank ... I like to start and run the truck once or twice a month .. Battery is not that easy to get out while in the trailer ... I do have a kill switch though
Old 11-10-2011, 07:45 PM   #7
Clydes 31 P/U
No mention of checking anti freeze or draining the water. Just askin.
Clydes 31 P/U is offline   Reply With Quote
Old 11-10-2011, 07:47 PM   #8
Pepsi Mechanic
location LONDON ... your here !!! If you ever want to see her Dave let me know .. I am in charge of her and she is at the Pepsi plant here .. good idea about the vent .. got the gas stablized
Old 11-10-2011, 07:48 PM   #9
Pepsi Mechanic
Got a 50/50 mix
Old 11-10-2011, 08:12 PM   #10
Dave Boyer
I don't live far from Pepsi, I'm in Westminster Park, I was over at Krown the other day, so I drove right by, and didn't know it. I'd love to come see it some time. Krown makes a oil spray, it's cheap insurance to coat anything that is bare metal.
Old 11-10-2011, 08:13 PM   #11
Milton
Milton's Avatar
Are you planning on blocking it up off of the tires?
Milton is offline   Reply With Quote
Old 11-10-2011, 08:57 PM   #12
Pepsi Mechanic
I was not going to ... mmmm might not be a bad idea
Old 11-10-2011, 09:03 PM   #13
Pepsi Mechanic
I buy lube from there for Pepsi .. I sent you an Email
Old 11-10-2011, 11:34 PM   #14
Peter J
Peter J's Avatar
I've read some strings discussing running the engine during storage and the answer was NO because of not completely warming up the oil and causing condensation problems. 10-15 mins. was not enough from what I remember. Just a thought.
Pete
Peter J is offline   Reply With Quote
Old 11-11-2011, 03:39 AM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with Peter. I already parked mine a month ago and won't touch it for the next five months. I usually change oil just before parking it, but didn't get that done this year. An occasional battery charge for an hour would be fine for the battery, but I don't do that either and the car starts right up in the spring. I always throw moth balls around the garage and in the car and never see a sign of a mouse. I also set mouse traps just on the outside of the garage door and catch a few mice. The neighbor's cats come over and make the rounds about 3 times a day and they are great hunters.
Old 11-11-2011, 06:02 AM   #16
Pepsi Mechanic
Thanks Tom , and Peter .. Not starting her up is a good idea .never thought about condesation .. always good to get advice from all .. The truck was parked for 13 years and with new plugs , fuel and battery she fired up so I guess 4 months in a trailer won't hurt
Old 11-11-2011, 07:45 AM   #17
jim1932
jim1932's Avatar
I would throw a bunch of mouse traps in there as well. Get them before they get you.
jim1932 is offline   Reply With Quote
Old 11-11-2011, 07:50 AM   #18
Tom H.
Tom H.'s Avatar
Regarding the mice, I keep traps set in the garage all winter long. I also like to stuff some steel wool in the tail pipe and carb intake.
Rear fenders and running boards for 1932 131" single wheel Express Body needed.
Tom H. is offline   Reply With Quote
Old 11-11-2011, 12:06 PM   #19
CarlG
CarlG's Avatar
I thought I had gotten rid of the mouse problem. I still had an unopened box of Decon out in the garage. The mice found it and chewed it open.
Old 11-11-2011, 12:39 PM   #20
ratamahata
ratamahata's Avatar
Care of tires when car is stored: When a car is idle for any appreciable length of time, It should be jacked up to take the load off the tires, If the car is laid up for several months, It's is best to remove the tires, Wrap up the outer casings and inner tubes separately, and store them in a dark room not exposed to extreme temperatures. Remove oil o grease from the tires with gasoline. This text is a extract from the "engine chassis manual"
ratamahata is offline   Reply With Quote
