Old 02-03-2021, 09:38 PM   #1
Randall
Randall's Avatar
Default 32 shop manual
I have David G books but would also like a shop manual, are the green 32-48 e bay one a copy of Fords original? thanks
Randall is online now   Reply With Quote
Old 02-04-2021, 12:46 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 32 shop manual
If this is it ,yes its a reprint.
https://pulsar.ebay.com/plsr/clk/0/S...e8200276%22%7D
deuce lover is offline   Reply With Quote
Old 02-04-2021, 08:03 AM   #3
Randall
Randall's Avatar
+thanks deuce
Old 02-06-2021, 09:41 AM   #4
hop up
hop up's Avatar
Randall the green book is more of a parts number book then a shop manual
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 02-06-2021, 04:50 PM   #5
JSeery
JSeery's Avatar
This is what is often referred to as the "Green Book". It is a great book to own, but not a repair manual. When you go to order a book (repair or parts) be sure you know which one you are getting. The chassis parts book is great to determine which parts fit which model/years. But, it was for shops to use as in what would fit, it is NOT correct for "as it left the factor" parts.
Old 02-06-2021, 06:00 PM   #6
rotorwrench
rotorwrench's Avatar
If the 1932 was anything like the model A in content of manuals, it may also be a good idea to purchase the Ford Service Instructions for at least 1932 as a companion to the shop manual. There is another 1932 through 1937 Service Bulletin manual available from some sources. Here are links:
http://www.faxonautoliterature.com/1...nt-P13076.aspx
https://www.themotorbookstore.com/19...echanical.html
You can never get too much information about old Fords.
This is another one but I don't know what the best ones are if a person is only looking for one book to fit all needs.
http://www.faxonautoliterature.com/1...int-P9146.aspx
CD-Rom are also available:
https://www.faxonautoliterature.com/Search.aspx?c=3264
Old 02-06-2021, 06:47 PM   #7
DavidG
DavidG's Avatar
The '32 (only) service bulletins and '32 chassis parts catalogs reprints are frequently listed on ebay and Amazon inexpensively. The green cover book cited by deuce lover is not a reprint of an original Ford publication, but it is worthwhile. If you are interested in originality as you seem to be given your spring shackle bushing thread, avoid the big green parts catalog as it may mislead you as JSeery points out. It only lists service parts still available sixteen years after your car was built and often they aren't the same parts as those the car was built with.
