06-04-2018, 02:20 PM | #1 |
what caused this?
outer cap on my 36 w/ Bubba rebuilt helmet
pics will not load! I'm referring to the inside center "tower" of the cap...It's corroded Last edited by 36 ford; 06-04-2018 at 03:58 PM. |
06-04-2018, 02:52 PM | #2 |
Re: what caused this?
What is the size of the file you are attempting to load? If you need help you can email it to me and I'll post it for you.
06-04-2018, 04:00 PM | #3 |
Jerry, Thanks as always! You are my helper all the time. I took some smaller size images and I hope some answers come.
Phil |
06-04-2018, 04:16 PM | #4 |
What caused what?
The end of the centre protrusion has broken off. Normally this sticks through the side cap and a thick O ring type of deal helps hold the two pieces together. What probably happened is that the side cap stuck in place, and the cap broke by being levered off. I have filed the od of the inner caps down before now to make them fit. Mart. |
06-04-2018, 05:00 PM | #5 |
Thank you kindly, Mart
06-04-2018, 07:26 PM | #6 |
06-05-2018, 05:01 PM | #7 |
If that is an original bakelite cap, maybe the old bakelite just failed. Replace with a plastic one?
