Old 05-24-2016, 02:32 PM   #1
supergnat
supergnat's Avatar
Default Is this a steel drum?
My 28 has drums which look to be of the same type. I think they are steel but I want to be sure. Please let me know what you think.
Thanks for your help.
Supergnat
supergnat is offline   Reply With Quote
Old 05-24-2016, 02:43 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Is this a steel drum?
Yes, it appears to be. You can tell by the way the lip is bent over. The Cast Iron Drum does not have the void.
Old 05-24-2016, 02:53 PM   #3
supergnat
supergnat's Avatar
Great. Thanks for the quick reply. All for of mine have the turned up lip. They actually appear to be in great condition that is if my drun gauge is accurate.
Thanks again.
Supergnat
Old 05-24-2016, 08:23 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
It's easy to tell if a steel drum has been turned by the line left at the end of the outside cut. Uncut drums will have a smooth roll with no line. I buy and use drums with no lines, but if your drums have been cut and need to be replaced, it's a good time to install the cast drums.
Old 05-24-2016, 08:31 PM   #5
MikeK
MikeK's Avatar
F.W.I.W., the thermal expansion rate of steel is nearly double that of cast iron. That's why steel drums fade much quicker than iron drums. Fine-point, you need the steel drums. Driver, use iron drums, preferably ductile iron.
MikeK is offline   Reply With Quote
Old 05-25-2016, 05:52 AM   #6
supergnat
supergnat's Avatar
Thanks for all the information. I'll check my drums carefully and decide how to proceed.
Old 05-25-2016, 09:11 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I lucked out, Vermin has perfect .010 OS, steel drums & new woven lining that has only a few stops on them!!!
Bill Blessed
"THE ASSISTANT GURU OF STUFF"
Old 05-25-2016, 10:48 AM   #8
Y-Blockhead
When I first adopted the Town Sedan it had Steel Drums with "Molded" brake linings. Talk about a scary ride the FIRST time they got hot . I had never driven a car that had brake fade that bad before. BOTH feet on the peddle and we still ended up blocking the cross walk with a little help from the parking brake!! . (Luckily there where no pedestrians or other cars).
My wife said she would never ride with me again until I got it fixed. I have since replaced all brakes with Ductile Iron drums and woven brake linings.
