01-17-2014, 07:19 AM | #1 |
OD wiper motor repair - taper pin? - ANSWER FOUND
I am repairing my OD-C1B wiper motor. The new wiper blade support arm needs to be installed but it did not come with a taper pin. I cannot figure out which taper to use since I don't have the old one. It appears to be a 5/0 taper pin but that size will not fit through the original hole in the shaft. I purchased the 6/0 and 7/0 sizes and they are both too small. Do taper pins come in a variety of tapers or has their design changed since my motor was manufactured. I"m not sure if I should just enlarge the hole and use a larger size pin.
Thanks for any help in advance. Supergnat Last edited by supergnat; 01-23-2014 at 08:20 PM. Reason: Found answer |
01-17-2014, 10:36 AM | #2 |
Re: OD wiper motor repair - taper pin?
Do not remember mine having a taper pin. I used a roll pin and it seemed to work fine. Possibly over the years the hole has become worn from use.
01-23-2014, 08:26 PM | #3 |
Re: OD wiper motor repair - taper pin? - ANSWER FOUND
Supergnat |
Thread Tools | |
Display Modes | |
