#1 |
How to open hood on 50 Ford passenger car with broken hood cable ?
#2 |
There is some good ideas on opening the hood in the attached post.
https://www.fordbarn.com/forum/showt...ght=hood+cable |
#3 |
I cant help you with that. However because of this problem I have attached a wire under the hood to the latch mechanism. It is a wire that is attached to the release lever and when you pull the wire it pulls the release lever to the left and will release the latch. Make a loop in the end of the wire to pull on and hide it behind the upper grill bar. Works great!!
#4 |
I know from experience it takes around1 1/2 hours to remove the grill to get at the latch , lots of words not exercised for a while got some practice.
#5 |
That reminds me of one I heard when I worked in St. Paul: Ma Ma, can I listen to Daddy put the chains on the car?
#6 |
Thanks to everyone for the help. |
Thread Tools | |
Display Modes | |
