Old 11-14-2020, 06:23 AM   #1
jerrytocci
Default Gas cap 30/31 VENTED ??
How can I tell if my new cap is properly vented and how to fix it if it is not
jerrytocci is offline   Reply With Quote
Old 11-14-2020, 07:27 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Gas cap 30/31 VENTED ??
Is the engine running properly ?
A new cap should be vented correctly. But look at the underside, remove the gasket and look at the vent hole[s].
Old 11-14-2020, 08:23 AM   #3
jw hash
jw hash's Avatar
unhook your gas line from your carburetor and put the end of line in a can, turn on the gas and see if it run free for a minute or so. if it slows down at all open the cap. if it is not vented good enough. you will see the difference in the flow.
jw hash is offline   Reply With Quote
Old 11-14-2020, 08:32 AM   #4
McMimmcs
McMimmcs's Avatar
Is this a new to you cap or a brand new cap? Is it a reproduction cap?
McMimmcs is offline   Reply With Quote
Old 11-14-2020, 11:06 AM   #5
jerrytocci
it's a re-pop and I suspect something . I can't blow air through the cap
Old 11-14-2020, 11:13 AM   #6
katy
katy's Avatar
It sounds like you have a radiator cap.
Old 11-14-2020, 11:23 AM   #7
jerrytocci
There is a small hole in the underside but I can't blow air through it . Do I run a drill through it ??
Old 11-14-2020, 01:07 PM   #8
Tom Endy
Tom Endy's Avatar
Lay the cap on a flat surface bottom side up. Fill the outer rim with water and blow through the vent hole with a straw. Bubbles should appear in the outer rim. See attached article.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 11-14-2020, 01:08 PM   #9
jerrytocci
can't remove gasket
Old 11-14-2020, 01:13 PM   #10
jerrytocci
thank you Tom
Old 11-14-2020, 03:04 PM   #11
Bob C
The radiator cap is smaller than the gas cap.
