07-15-2020, 05:11 AM | #1 |
39 brake drums
just a question for the future does anyone make replacement wide 5 drums
07-15-2020, 07:27 AM | #2 |
Re: 39 brake drums
I have never seen them advertised by any of the big suppliers.
07-15-2020, 09:41 AM | #3 |
Re: 39 brake drums
There is a company I believe in the mid west that rehab's brake drums. Not cheap IIRC. I have the contact info somewhere (I think). Maybe someone will chime in with the info.
Found it: https://www.jgrelining.com/
Making the simple complicated for over 30 years. Last edited by 51504bat; 07-15-2020 at 09:50 AM. |
07-15-2020, 09:59 AM | #4 |
Re: 39 brake drums
If you get a price from them, could you let us know? I am afraid it will be very high (that company specializes in redoing Pontiac 8-lugs, and you know how much money those guys have).
07-15-2020, 01:21 PM | #5 |
Re: 39 brake drums
I believe there's a couple on the HAMB for sale, also here on the BARN.
Paul in CT |
07-15-2020, 03:27 PM | #6 |
Re: 39 brake drums
I found some at Hershey but tough to find them with any meat left |
07-16-2020, 03:07 AM | #7 |
Re: 39 brake drums
J&G Relining!! used them for my drums, Top Notch ! They will also arch your shoes. They are on the web
07-16-2020, 03:47 AM | #8 |
Re: 39 brake drums
hello aussie merc if you need some drums ive got a perfect set
07-16-2020, 08:17 AM | #9 |
Re: 39 brake drums
MT Car Products
From their website "These drums will work with our backing plates or with original 1939 - 1948 ford hydraulic backing plates. They come in the stock 5 on 5-1/2" pattern. Sold each $135.00" They must be used with hubs that mount inside the drums 39-40. When I talked to him he said 46-48 with hub on outside will not work. Has anyone had experience using them? Dave/Green Bay www.mtcarproducts.com/ |
07-16-2020, 09:01 AM | #10 |
Re: 39 brake drums
I couldn’t find my quote from J&G but if memory serves me they were just north of $300for Drum and shoes (1935 Ford). From their website they work on a wide scope of drums and the quality looks superb. The drum is restored to original.
Since original drums are still popping up I elected not to go down this road yet.
Tim Downtown, Ca |
07-16-2020, 09:29 AM | #11 | |
Re: 39 brake drums
Making the simple complicated for over 30 years. |
07-16-2020, 09:52 AM | #12 |
Re: 39 brake drums
Just call J&G and it is around 300 dollars per drum to repair to std.
07-16-2020, 10:28 AM | #13 |
Re: 39 brake drums
what do they do, sleeve it, or spray weld it back to size?
07-16-2020, 04:36 PM | #14 | |
Re: 39 brake drums
Be careful how you read this info. The "drums 39-40" quoted above is incorrect, as '39 drums are WIDE FIVE. That should read "drums '40-'41". What they are actually TRYING to say is that their '40 -'41 replacement DRUMS will function properly and fit properly when using '39-'48 hydraulic backing plates. NOTE...that wheel studs will have to have the swages cut and each stud removed to separate hub and old drum. The swaged studs must be cut and removed PROPERLY so as not to bend hub's flange. The MT parts are of the utmost quality. Don't settle for the Speedway 'look-alikes'! They ain't the same as MT drums. DD |
07-16-2020, 04:39 PM | #15 |
Re: 39 brake drums
cas…..I'm 99.9% sure that I've read that they re-sleeve the drums. Their web site is interesting. Someone linked it above. DD |
07-16-2020, 04:58 PM | #16 |
Re: 39 brake drums
thanks coopman
07-16-2020, 05:15 PM | #17 |
Re: 39 brake drums
I know 300 a wheel seems like a lot but a disk conversion can be expensive. The new Mustangs have some mega dollar super brake option. They can keep the pretty painted calipers, wide 5's are total class.
07-16-2020, 06:58 PM | #18 |
Re: 39 brake drums
Interesting.... sleeve back to size? Using WHAT for material?
07-16-2020, 07:59 PM | #19 |
Re: 39 brake drums
Guys...…….: Our Services include:
We are the only company that uses a THREE-STEP PROCESS to install new cast iron liners into the drum. Why? We value safety! CHECK-OUT THEIR WEB SITE! They use cast iron liners! They show pictures of the process, PLUS the repair of broken parts of the same aluminum Pontiac wheel. They do some high-dollar, irreplaceable stuff. Make sure you click on "PHOTOS". Click on the link below! DD https://www.jgrelining.com/ |
07-18-2020, 09:49 PM | #20 |
Re: 39 brake drums
yeh thanks got a price to rebuild drums with metal spray localy not cheap but still reasonable when you add up the on costs of changing to 40s or going all out with full discs As i said a question for the future thanks for all the input
