Old 03-29-2020, 06:58 PM   #1
Farley's34
Default 1932 Medium Maroon
Does anyone have a formula that matches well in today's paint system ?
Farley's34 is offline   Reply With Quote
Old 03-31-2020, 08:52 AM   #2
Strick
Strick's Avatar
Default Re: 1932 Medium Maroon
would like to know this as well...
1940 Mercury
Looking for DENVER heads - 81AS - 99AS - 19AS
Strick is offline   Reply With Quote
Old 03-31-2020, 09:26 AM   #3
DavidG
DavidG's Avatar
Have you tried autocolorlibrary.com?
Old 03-31-2020, 11:11 AM   #4
Farley's34
Yes, David, I have. The only thing listed is the original code IM-1248 which is no longer available. I able to find that Ford my have recycled this color in 1986, stay tuned...
Old 03-31-2020, 12:24 PM   #5
DavidG
DavidG's Avatar
The original color is slightly muddy, unlike the '36 light fast maroon and the '40 Mandarin maroon. The latter two likely avoid the brown tone by being produced with a bit of gold. (in paint and glass pure reds, maroons, and purple require gold to kill the mud; I am not making this up as those colors when true always cost more to produce and therefore are more expensive to buy.)
Old 03-31-2020, 12:48 PM   #6
Jersey Devil
Jersey Devil's Avatar
Model A website indicates Ford Maroon for 29,30,32 as DSO 56 DuPont, 1011 PPG. Ford Maroon medium for 31, as DSO 64 DuPont. Perhaps a quality auto paint store could use these codes to find a match.
Hope this helps,
Tom
Jersey Devil is offline   Reply With Quote
Old 03-31-2020, 01:40 PM   #7
Farley's34
Gentlemen,
I have been in the Body Shop business for the past 35 years so I am aware of how to research my color options. If someone had a match for this color it would have just saved me a lot of time. So thank you for your responses! My painter spoke with the PPG color library and they informed us that 1986 Ford code 2Y Midnight Wine should match up. We will mix it up shortly and post the result. Thanks Again!
Old 03-31-2020, 01:54 PM   #8
34Jerry
Check paintref.com.
34Jerry is offline   Reply With Quote
Old 03-31-2020, 03:39 PM   #9
Farley's34
paintref.com and autocolorlibrary.com only supply the original paint manufacturers codes. They do not have formulas or cross-reference information. The code I listed above looks great!
Old 12-14-2020, 04:39 PM   #10
Farley's34
I have a new custom mix PPG formula that can be mixed in either single or two stage application if needed.
Old 12-25-2020, 11:32 AM   #11
hotrodA
hotrodA's Avatar
Any update? Have you sprayed a test card?
hotrodA is offline   Reply With Quote
Old 12-25-2020, 12:27 PM   #12
John R
Farley,
Sounds like the PPG recommended 2Y Midnight Wine wasn't quite correct and you had to develop a "custom mix PPG formula" to match up. What is the source of the original color you are using to match up your formula?
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 12-25-2020, 08:20 PM   #13
Farley's34
The PPG paint technician modified PPG mix number 52914 to an exact match.
