02-20-2020, 05:12 PM | #1 |
Valve Guide Seal Installation The Easy Way
Hi Guys-
Thought I would share my idea with you for installing those pesky rubber seals on your valve guides. Anyone who has access to a lathe can make this handy little tool and save themselves sore fingers. It's made of aluminum and is basically a double cone. Check out the pictures. The cone is 1 inch long and is 11/16" at the small end and 1.030" inch at the large end. The diameter at the small end isn't critical but the large end diameter needs to match that of your guides. The inside cone is turned to match the angle on the end of your valve guides and it is drilled and tapped for a 5/16" bolt. That inside cone keeps the cone centered on your guide while the ring goes on. Just oil things up and push the ring on. Simple. |
02-20-2020, 05:40 PM | #2 |
Re: Valve Guide Seal Installation The Easy Way
I like that very much.
Wayno
Life is not a spectator sport. |
02-20-2020, 05:55 PM | #3 |
Nice workmanship on that tool
02-20-2020, 06:55 PM | #4 |
Never had particular difficulty getting the o-ring on the guide itself. The bigger problem has been getting the guide into the guide bore without the o-ring hanging up. On intakes, once the o-ring is put on the guide, I use an exacto knife to shave approximately 1/32” off over ~1/3 of the o-rings' circumference (before applying lubriplate & inserting into block). Then I orient the shaved portion of the o-ring toward the intake port (sharp edge of guide channel) so it eases in to the guide bore.
02-20-2020, 07:23 PM | #5 |
Never use them. RV works very well. However, that is an interesting tool. One thing ablut flathead builders, most a lazy, so they make things easier.
02-21-2020, 10:49 AM | #6 |
Will it work for "square edged" seals? |
02-23-2020, 05:04 PM | #7 |
where can I buy the correct "O" rings for the guides instead of the stock square cut quad ring style seals , are those rings a Viton , Butyl rubber, silicone or neoprene material ? I have looked and can't locate the correct size rings, we have a supply house here that can get or make what I want if I can give them the size and material I want.
thanks |
02-23-2020, 08:03 PM | #8 | |
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
