12-26-2019, 06:12 PM | #1 |
Identify this alternator
Purchased a speedster based on 1931 Model A. It has been converted to 12 volts and this is the alternator. Is this a GM 10si? Just wanting to know for future reference. It is single wire and negative ground.
12-26-2019, 07:45 PM | #2 |
Re: Identify this alternator
It’s a DELCO 10Si
12-26-2019, 09:05 PM | #3 |
Keep in mind that a stock 10si is NOT a one wire alternator. To convert a stock 10si to a one wire requires a kit to replace the stock VR with a self exciting one...
https://alternatorparts.com/self-exc...tallation.html Unless you are trying to eliminate a couple of wires in the engine compartment, I recommend sticking with a stock 3 wire 10si. It starts charging immediately and doesn't need momentary high RPMs to excite the VR. You also get a lead to an "idiot light" (if you choose to use it) that will tell you if it fails.
All steel from pedal to wheel |
12-27-2019, 08:29 AM | #4 |
Thanks, Eric |
Thread Tools | |
Display Modes | |
