Old 06-29-2019, 06:45 PM   #1
Werner
Werner's Avatar
Default Tillotson versus Zenith carburetor
Hi, is it a big difference between Zenith and Tillotson carburetor at the ride / setting? My car may need a replacement carburetor. On Ebay, the Tillotson are noticeably cheaper than Zenith offered. It even reads that Tillotson should be better.
How are the practical experiences please? Very thanks in advance!
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 06-29-2019, 10:11 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Tillotson versus Zenith carburetor
This has been covered many times and many have varying opinions on them. Some people don't like Zeniths, and others only run Zeniths and think that the others are junk. Do your homework and decode what you think is best for your car and engine.
https://www.fordbarn.com/forum/showt...ight=Tillotson
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-30-2019, 07:36 AM   #3
jhowes
Don't be afraid to look into the Marvel's. I have all three and for cruising I prefer the Marvel. It seems to have more zip and the mileage is good. Jack
jhowes is offline   Reply With Quote
Old 06-30-2019, 07:58 AM   #4
leo
leo's Avatar
This is purely an assumption on my part. I believe the Tillotson or Marvel probably are better designed carburetors because they proceeded the Zenith, making improvements to correct prior deficiencies. Having said that if you are a purist nothing but the Zenith will do.....
leo is offline   Reply With Quote
Old 06-30-2019, 08:03 AM   #5
Patrick L.
Patrick L.'s Avatar
All 3 are good carburetors when set up correctly. Why not just clean and set up your Zenith ? As far as your question though, the Tillotson likes more fuel/GAV
Old 06-30-2019, 08:33 AM   #6
Werner
Werner's Avatar
Hallo, I have the problem that my Roadster is drinking too much. I opened the Zenith-2 at least 10 times and put the float higher or lower. Set the level with gauge tube. Have changed all the jets against the set of Snyder. Then the nozzles built by David Renner. The GAV valve fitted. All holes cleaned with drilling cabel. All parts with ultrasonic and dish tabs.
The idling air nozzle is 3/4 open, the GAV <1/8 open.
For 100 km I use 20 liters. That's 12-13 miles per gallon.
Ignition perfect with stroboscope, new spark plugs iridium, compression 4 bar, oil consumption 1/2 quart / 500 ml.
Without airfilter, the car runs a little faster (unimportant) but even more rough.
Therefore, I would like to stop experimenting and replacing nozzles, but perhaps try a complete different carburetor.
Werner
Citroen 11 CV, 1947
Old 06-30-2019, 11:56 AM   #7
Jim Baskin III Pa.
Jim Baskin III Pa.'s Avatar
I have run both Tilly and Zenith carbs.,putting 1000's of miles on each from climbing mountains to 4 lane highways. And to date a Zenith carb. restored with Renner's Corner flow tested jets is the best one of all.
Just got back about an hour ago for a 3 day 331 mile trip in the Pa mountains and the car ran flawlessly with the Zenith carb. I have a 30 Tudor and got 21 miles per gallon.
Jim Baskin III Pa. is offline   Reply With Quote
Old 06-30-2019, 01:03 PM   #8
1930artdeco
1930artdeco's Avatar
I am assuming that your engine is like our engines and not like the British engines. But 12 or so mpg is really low. My zenith on my rebuild let’s me cruise between 50-55 and I am guessing I get around 20 mpg. I am running Renners jets inside and they is all- no air filter as that will cause your mileage to go down. However, I love my Marvel for its power and mpg.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-30-2019, 01:42 PM   #9
john charlton
john charlton's Avatar
I decided to experiment to see which carburetor would give the best economy and performance . Over the years I have collected many . The Marvel ran OK about the same as the Zenith but with a Tillotson it runs the best .More power and better gas mileage . I tried 4 different Zenith and several Tillotsons . All these were clean and correct float height . It just seems my P/U loves Tilly best !!! . At swap meets Tillotsons are plentifull and very cheap normally in the $5 $10 nobody seems to want them but I think they are a very good unit certainly equal if not better than the Zenith . One good point is that they do not stall out on heavy braking as the Zenith sometimes does . On idle they they are not as smooth and wont "tick off" like a Zenith can but that does not bother me .
John in a hot summers evening Suffolk County England .
john charlton is offline   Reply With Quote
Old 06-30-2019, 02:00 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
No, as for price most want what Ford used so demand is higher.
Old 07-01-2019, 04:51 PM   #11
eagle
eagle's Avatar
The saying is: Zenith for the show car Tilly for the Go car. That being said, I've got a Zenith on mine, just because thats what was on it when I got it and its never needed anything as far as service, runs great. I have a Marvel cleaned and rebuilt to put on if I ever need it. Tilly sitting around too somewhere.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 07-01-2019, 05:08 PM   #12
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I have run all three carbs. The Zenith is a good carb and runs well. I have it under my seat as a backup carb. However, I now have a Marvel Shembeler on my A. I like it the best. I think it gives you more power at higher speeds. They only thing I would say that is critical of the Marvel is you can never give it any throttle when starting either a cold or hot engine. I found that if you just pull the choke and immediately drop it it will always start. Other wise, you can flood the engine.
If you are interested in a Marvel, there is a fellow in Texarkana, TX that does nothing but sell rebuilt Marvels. He rebuilds them and is the Marvel guru. His name is JR Bullock and his telephone number is 903-748-8229. He charges a flat $200 and ships free in the US. He is also listed on Ebay.
Viel Gluckness!! = (Good Luck)
Dick M is offline   Reply With Quote
Old 07-02-2019, 09:19 AM   #13
xmarine
xmarine's Avatar
I second JR Bullock.He also rebuilds tillys.A real nice guy
xmarine is offline   Reply With Quote
Old 07-02-2019, 12:22 PM   #14
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Does anyone have any experience with the Simmons carb?
How does it compare?
Does anyone rebuild them?
I have one, somewhere, but have never run it.
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 07-02-2019, 03:27 PM   #15
Peyton
Marvel, Tillotson, and Zenith all seem to be good carburetors from my experiences with them. It's really hard to say which is best.
I remember getting good gas mileage from my Tillotsons. A little more power with the Marvels. But, I'll give the edge to Zenith for overall smooth performance.
Peyton is offline   Reply With Quote
