12-18-2020, 01:58 PM | #1 |
mallory distributor
Any worth while benefit in installing A vintage dual point mallory in A 53 mercury flathead ,stock except for hedders ?
12-18-2020, 02:46 PM | #2 |
Re: mallory distributor
My opinion, only if you are looking for bragging rights and oooh's and
aaah's |
12-18-2020, 02:46 PM | #3 |
Not really. When I ran a Mallory dual point on my stock 50 Merc. I didn't notice any difference in performance. Now days, high quality points and condensers are getting harder to find. Here's some good reading.
https://www.jalopyjournal.com/forum/...enefit.547992/ and https://www.google.com/search?q=adva...hrome&ie=UTF-8 If your engine is now running fine, let it be. |
12-18-2020, 02:50 PM | #4 |
Absolutely....be sure the curve is flathead friendly. Stock is a sometimes thing with
flatheads....swap meet ( remember them ) 2x2 setups can be enticing. Any mods will go better WITHOUT the Load a Matic. Charlie ny |
12-18-2020, 11:26 PM | #5 |
Mine runs better but, I replaced a worn out Load a Matic.
12-19-2020, 08:52 PM | #6 |
12-20-2020, 11:42 AM | #7 |
Most folks change due to getting away from the original carburetor and Load-O-Matic system. Dual point set ups will increase the dwell time for the coil and thus allow for a better spark. As was mentioned, make sure to get the springs & flyweights adjusted for best spark control for the engine application. There will be no benefit for under load spark control but this will only give a lesser amount of fuel mileage overall. If a later modified vacuum advance type distributor such as a GM unit is utilized & properly adjusted then the mileage would be better. Most modern coils function well enough without dual points but it always has some benefit.
12-20-2020, 10:35 PM | #8 |
In earlier years it was mostly for the cool factor on basically stock engines. Dual pipe, distributor change, these type of things were simple and relative cheap modifications to give you a cool look under the hood.
