11-28-2020, 08:00 AM | #1 |
Need help balancing wheels
I know this is a little bit off topic but it is vintage.
I have an old bubble balancer Bada from the 1960s. I pulled it out yesterday to balance some wheels and the liquid is gone from the bubble. Has anyone had to deal with this? What type of liquid to us? Mineral oil? Clear HYD oil? It looks like I can drill the 4 spots that when peeled over on the bottom and hopefully can add fluid from the bottom? Any ideas? |
11-28-2020, 08:50 AM | #2 |
Re: Need help balancing wheels
Looks like a Micro Precision. I have no idea about drilling any holes, the oil goes into
the top. You don't want light oil in there we stayed around 80 or 90 gear oil so the hub with the bubble stays stabilized; with light oil the slightest breeze even from a fan will drive you crazy. Remember the proper way is to use two weights one in front, one in the back but sometimes you need four small weights placed on the front mark rim with chalk for the back then bang them all in then recheck. We have one looks like yours been in storage since can't remember, because today's tires are pretty well or close to balance v/s tires with 'tubes' that need balance....... |
11-28-2020, 08:59 AM | #3 |
Again I misread the post. oh so its the cross hair bubble. How did that happen ?
Maybe the glass seal dried up don't know. can't think of the name but I bet its the same fluid used in gauges and levels google levels vile's and such....maybe you could drill a small hole in the glass fill with ???? an eye dropper plug hole after a guess? |
11-28-2020, 09:48 AM | #4 |
on ebay under (level bubble)
they have round bubbles might take a look and replace your old bubble |
11-28-2020, 11:18 AM | #5 |
11-28-2020, 11:17 AM | #6 | |
11-28-2020, 02:08 PM | #7 |
I used beads. perfect results. Ken
11-28-2020, 03:10 PM | #8 |
Do you use them and all your vehicles or just the old ones?
I had the old guy at the gas station 30 years ago told me of an older guy that would come in and want a cup full or half a cup of sand put in each one of his tires before mounting them. No external balancing. |
11-29-2020, 08:36 AM | #9 |
Same here, just takes a bit of patience to get them in an inner tube
Aim low--achieve your goals. |
11-28-2020, 03:06 PM | #10 |
I picked up a bullseye level from the hardware store I think it will work.
11-28-2020, 03:43 PM | #11 |
The motorcycle guys love the beads, at least my kids do.
11-28-2020, 05:31 PM | #12 |
36coupe. Just a suggestion for the level you picked up. Find as level a surface as you have handy, and place the level on it. Let it settle, and look at where the bubble is. Rotate 90 deg. and check the bubble. do the rotation thing again, and if the bubble is always zero, your good. The reason I suggest this, is that I bought one a few years ago, and it was off center.
11-28-2020, 06:15 PM | #13 |
Starret has a bubble level with stickie on the back . Ive been using mine for a few years like that now .
11-29-2020, 04:40 AM | #14 |
i was a sceptic about the beads but used them on my current tyres now a believer and no need to rebalance when rotating tyres
11-29-2020, 09:02 AM | #15 |
I take mine to a shop with a modern spin balancer and
have them do them with the drums attatched. G.M.
www.fordcollector.com |
12-01-2020, 09:16 PM | #16 |
Good suggestion on balancing with the drums/rotors as you are balancing the complete rotating assembly. We've found it necessary to do this more than once to balance a pesky one.
