06-28-2012, 05:07 PM | #1 |
Torque setting on manifold
I don't remember what is the torque setting on the manifolds.
06-28-2012, 05:37 PM | #2 |
Re: Torque setting on manifold
try 30 Cold....Drive and go to 35...That is ALL i do, i know some folks will say 45 or 55 but not fun when those ears make that fun "SNAP"
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
06-28-2012, 05:42 PM | #3 |
Just "good and tight" with a short handled socket wrench. As Mark said, you don't want them talking back to you!
06-28-2012, 05:43 PM | #4 |
Thank you.
06-28-2012, 05:54 PM | #5 |
James,
Say, "thank you that I didn't reply!" Seems that everytime I mention torque, Loctite, or pre-load, I get folks all stirred up! Bill W.
06-28-2012, 06:03 PM | #6 |
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
06-28-2012, 07:53 PM | #7 |
Like said, 35-40 ish.. They didn't torque them back in the day.. They just snugged up up evenly..
06-29-2012, 01:36 AM | #8 |
They were ignorant about torqueing, that was a looooong time ago. A lot of things were learned since then.
Their motto was probably: little bolt, a little tightening, medium bolt, a little more, a Big bolt, 2 GRUNTS, rear axle nut, 3 GRUNTS! Lots of things they did back then wasn't necessarily the best way. Bill W.
06-29-2012, 01:41 AM | #9 |
One of the best tools I have in my box is a copy of the Pocket Ref. You can go through an entire car and not know any torque settings for anything and get all the torques correct.
06-29-2012, 01:55 AM | #10 | |
I'm gonna order one, handy! Torque is so important, first to make sure it is tight enough, and also for uniformity. Worked with a shop IDIOT once that was always BREAKING bolts & "squishing" soft gaskets_*&%$#^# I spent a whole lunch hour teaching him TIGHTENING-101! Bill W.
06-29-2012, 09:33 AM | #11 |
Bratton's catalogue has a spec and torque table in the front, very handy. Good ol' Walt...
And the manifolds don't wanna be too tight because they are gonna move back and forth a bit from expansion/contraction of exhaust heat. If too tight, somethings gonna snap or warp.
'31 180A |
06-29-2012, 09:34 AM | #12 | |
Thanks again. |
06-29-2012, 12:30 PM | #13 |
James - You really need to get a copy of the Model A Ford Mechanics Handbook if you don't have one. It is worth it's weight in gold to us.
06-29-2012, 02:10 PM | #14 |
I don't know,, never torqued them before ,,,I just start left and right side nuts of the carb. and work my way out to the two ends. Keep going over and over,, left to right 2 inner to two outer so the gasket works to the outside edge and don't bind up. never had a problem. But everyone is different.Had both manifolds milled together.
06-29-2012, 08:03 PM | #15 | |
Catalogs are almost like a shop manual, if read completely. Are we too lazy to read? Shucks, we can a make a Model A run by the seat of our pants & a collection of parts catalogs! They even have PICTURES! You just gotta' stop & think things out. Can you imagine the questions a poor Model A parts man recieves, and his Dear Wife wonders why he's GROUCHY? Most modern manifolds are real tight, so they don't shrink and expand in length & shear off the studs. Datsun & Nissan "Z" cars for example. I've been around the "Horn" 2,870 times, I aint' no rookie! Bill W. (THORN!)
06-29-2012, 10:08 PM | #16 |
Modern Chevy and ford manifolds are cracking in the centers from being too tight and not leaving room for expansion. I run A manifolds at 45ft lbs after the manifolds have been cut together and the block has been checked true. Ive done over 30 of them in the past few years and have never had a problem.
06-29-2012, 11:02 PM | #17 |
There are other reference guides, both for specific torque values and for general torquing procedures, some of which are (or were) available gratis. Two that I obtained in 1989 when I was a mechanical engineer for the Oceanic Division of Westinghouse Electric Corporation were free from an automotive parts store across the street from our offices. Both were from Fel-Pro Incorporated of Skokie IL; the first is “Fel-Pro 263-85 Gasket Installation Manual” and the second is “Fel-Pro 486-89 Complete Cylinder Head Torque Specifications” (including torque-to-yield information, not applicable, insofar as I know, to Model A’s).
The “Gasket Installation Manual” has chapters on 'Things You Should Know About Every Gasket Installation'; as well as 'Cylinder Head Gaskets'; 'Manifold Gaskets'; 'Oil Pan Gaskets'; 'Timing Cover Gaskets'; and 'Adhesives, Sealants and Other Products Used in Sealing Gaskets'. While I suppose Fel-Pro might have a different slant on things than other gasket manufactures, they do appear to provide a “best practices” approach to what – at least in 1985-1989 – was the industry standard for proper gasket installation, assembly closure torquing, and use of gasket sealants. Here are some excerpts, applicable not only to this thread, but to several recent threads debating the use of not only torque wrenches but gasket sealants, RTV (sacre bleu!; Fel-Pro recommends the use of RTV for multi-part pan gasket joints), hot and cold torquing and retorquing, different approaches for cast iron and aluminum components, and… “Check for warpage and distortion [by placing] a straightedge lengthwise on the head surface, and slide a feeler gauge between the head and the straightedge. A good rule for flatness is not more than 0.004” out-of-flatness for four-cylinder heads” both lengthwise and widthwise. The same procedure – and specification - is recommended for the block. "If the [head or block] surface is too smooth, the gasket cannot grip the surface to give a good combustion seal. If the surface is too rough, the gasket will not confirm to the surface, causing fluid leaks. A finish of 90 to 110 micro-inches RMS [Root Mean Square] is preferred. Many head gaskets will not seal when the surface is outside this range.” “If the head or block has been resurfaced [or] if the threads run up to the surface, chamfer and retap the hole. The threads then will not be drawn above the [head or block] surface when the bolts are tightened [which] is enough to cause gasket failure.” “Wire brush the threads on all assembly bolts, check the bolt threads for damage and lightly lubricate the threads with engine oil before assembly. Dry…threads can decrease the bolt’s clamping force by as much as 50% [and] lead to false torque readings and possible gasket failure.” “Older [gasket] designs, such as the steel-faced sandwich-and-perforated-core, require the cylinder head to be retorqued [since] these gaskets take a set after initial engine operation and relax to the point where retorquing is needed to restore the clamping force. Run the engine to a normal operating temperature (usually 5 to 10 minutes), shut off the engine and carefully retorque the cylinder head bolts/nuts for a second time while the engine is still hot if the engine is cast iron. If the head or block is aluminum, cool to room temperature. Follow the torque sequence to the specified amount in the torque tables. Retighten a third time after 300 to 500 miles.” [Note that nothing was mentioned, either way, about breaking torque before retorquing.] “Some exhaust manifold gaskets have a perforated steel face on one side and a soft face on the other. The steel face is positioned toward the exhaust manifold…because the exhaust manifold expands when it is heated during operation [and] moves. Due to high heat conditions, it is important to retap and redie all threaded bolt holes, studs, and mounting bolts/nuts [to] ensure tight, balanced clamping forces on the gasket. Lubricate the thread with a good high temperature anti-seize lubricant [and] install the bolts/nuts finger tight [and] then tighten in three steps [to] ½, ¾ and full torque following the torque tables. Torquing…is begun in the center of the manifold, working outward.” Lots of good information from people who make a living making gaskets.
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. Last edited by Napa Skip; 06-30-2012 at 08:01 AM. Reason: typo |
06-30-2012, 12:12 AM | #18 |
Good stuff.
Installation manual: http://www.frontiernet.net/~tmeyer/fpro.html Torque Tables and the best explanation of torque-to-yield I have seen. None of this really applicable to Model A, but some of us work on lots of different engines http://olybrake.com/pdf/fel_pro_torque_specs_guide.pdf Glad to see the mention to re-torque cast iron stuff hot, and not cold. Some posters here are re-torquing cast iron cold, and that goes against any mechanical practice I have ever seen in > 60 yrs
'31 180A |
06-30-2012, 01:17 AM | #19 |
Even the Ford service bulletins call out torque warm.
06-30-2012, 09:56 AM | #20 |
I never use a torque wrench on manifolds.
Also you must remember that because a certain stud and nut can take some amount of torque, that doesn't mean the part being clamped can take the same amount of torque. Cast iron manifold ears on a soft copper gasket might fit in here. |
