10-21-2021, 02:10 AM | #1 |
'32 Model B ignition lock
Below is a letter received from the gentleman named within. I have his phone number, will PM to someone who can offer him assistance. He is in the SF Bay Tri Valley area.
Hi, Re: repair of locking ignition Wondering if your group could provide guidance. Have 1932 model B pickup (owned about 40 years) key broke off in locking ignition, had locksmith try to create new key without success. Now sitting until I resolve. Feel stuck, and afraid to take to someone unfamiliar with ignition, I am very willing to pay, just looking for someone to do the work. Thanks, Tom Richert (cell 925-989-XXXX) ~ PM for phone number ~
Alan |
10-21-2021, 02:43 AM | #2 |
Re: '32 Model B ignition lock
Alan .....Doesn't this guy John McClure do lock repairs and keys for F'Barn folks? Possibly duplicating key via door lock cylinder #? See the link BELOW. DD https://www.fordbarn.com/forum/showp...31&postcount=7 . |
10-21-2021, 02:51 AM | #3 |
Since the key is broken off the lock cyl will have to be removed.I have tried with dental pics with no success.
10-21-2021, 03:00 AM | #4 | |
Hey Sheldon ....I may be wrong, but it sounded to me like the locksmith had removed the key, but couldn't figure-out how to make a plausible new one. DD |
10-21-2021, 03:21 AM | #5 |
Ah okay DD. If the remains of the key is intact a key maybe be cut from that also if a code can be pulled off the cuts.If not The cyl will still have to be removed to have a key cut or take the car to the locksmith and have him try to pick the lock.The only person I knew that could do that is retired and is in Iowa.
Also maybe the door lock cyl would be a clue.same key? If unknown- remove and have a key cut to that code. There is a chance that it is. |
10-21-2021, 07:03 AM | #6 |
Perhaps a good first step might be to send a p.m. to 32phil and provide him with the rest of Tom's telephone number. Last edited by DavidG; 10-21-2021 at 07:49 AM. Reason: additional content |
10-21-2021, 08:56 AM | #7 |
IF the key is STILL broken off in the lock, try you tube as there are a few videos that my help, one using picture wires and another using a hot melt glue stick...the latter taking a few try's and a little know how of trimming the end of the glue stick.
10-21-2021, 09:58 AM | #8 |
Remember that the broken key can only be removed/extracted if the lock is in the locked position. (Locked column position)
10-21-2021, 10:31 AM | #9 |
Thank You DavidG
FlatheadCoupe is correct The cylinder must be in the off position. With some efforts already failing I suggest removing the cylinder and sending it to someone who can correct any issues with it properly without more damage. I have received way too many damaged cylinders beyond repair. I can help, PM me.
Early Ford Lock & Key Service http://www.fordbarn.com/forum/showthread.php?t=46583 Last edited by 32phil; 10-21-2021 at 10:32 AM. Reason: more info |
10-21-2021, 11:00 AM | #10 | |
...and I can vouch for Phil's superb workmanship and help with '32 locks! |
10-21-2021, 11:28 AM | #11 |
Me too!
10-21-2021, 06:54 PM | #12 |
Oh yeah!
10-21-2021, 10:54 PM | #13 |
There are ignition lock cylinders currently for sale on the FB Swap Meet section. Ad title is "32 33 34 35 36 37 38 39 40 Parts" Service replacements?
