Old 09-26-2021, 11:04 AM   #1
russcc
Default Brake backing plate ID
I have some front & rear backing plates I can't identify. I know what '39-41 & later 40's look like, but these stumped me. They have pins to mount the bottom of the Lockheed shoes instead of bolts. Need some help. Thank you.
russcc is offline   Reply With Quote
Old 09-26-2021, 11:44 AM   #2
ponymare
Default Re: Brake backing plate ID
The ones off my 47 1/2 ton look like that.
ponymare is offline   Reply With Quote
Old 09-26-2021, 11:52 AM   #3
42merc
42merc's Avatar
Plates shown are '45 thru '48.
'39 thru '44 have the eccentric lower anchors.
42merc is offline   Reply With Quote
Old 09-26-2021, 02:12 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
russcc ......If you'll refer to the GREEN-ish backing plate in my pictures (which is '42-'48), I also see POSTS like what you show. Can you show a picture more to the side rather than STRAIGHT-ON?
DD
THE OTHER SIDE
Click Links Below __
T5 W/TORQUE TUBE
Old 09-26-2021, 02:30 PM   #5
Mart
Mart's Avatar
To my eye the black ones look identical to the green one in every detail.
What makes you say you are familiar with late 40s plates but these are different? They look like late 40s plates to me.
Mart.
Old 09-26-2021, 05:22 PM   #6
russcc
Thank you for the responses. The B plates have pins at the bottom instead of through bolts for mounting the shoes. The shoes are retained by a plate slid over the pins, and held in place with cotter pins. Not like any 39-48 I have. The green one that V8 C posted looks like the outside of the plate, no bolt holes, pin anchors. Will get an inside side photo to post shot to show the mounting pins with cotter pins.
Old 09-26-2021, 06:19 PM   #7
bbrocksr
Those are 42-48 Lockheed. 39-41 had the holes.
Bill
bbrocksr is offline   Reply With Quote
Old 09-26-2021, 08:29 PM   #8
John R
42s are the same as 41s. The later type with fixed pins are 46-48.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 09-26-2021, 08:31 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
russcc ....Maybe a couple of better pics ....'42-'48, no BS! The PINS are obvious. DD
T5 W/TORQUE TUBE
Old 09-27-2021, 06:55 AM   #10
russcc
Thank you. 1st time I had seen ones with pins instead of bolts. So late '40's, 46-48. thank you all for your help.
