Old 09-10-2021, 09:03 PM   #1
skeazle
Default Where did my gas go?
I have a 1930 Tudor sedan that I keep at my In-laws garage when I'm not using it. About a month ago I took it over there and parked it there with about a quarter tank of gas and today I went over to start it up to bring it back home and it ran for maybe 1 minute then quit. I looked at the fuel gauge and it was plum empty. We know there is no foul play involved and there is no puddle on the floor so where could the gas have gone? Is it possible for it to have evaporated from the tank? The garage is not hot inside and the gas cap is on. This also happened to my sister-in-laws 1930 Woody after it was stored over the winter months. They know it had plenty of fuel when they parked it but when they went over to get it out of storage it was empty of fuel. Has anyone else ever had this happen? Lucky I only live 1 mile away so I put 1 gal.in and got it home. Jim
skeazle is offline   Reply With Quote
Old 09-10-2021, 09:13 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Where did my gas go?
Possibly shutoff valve seeped gas to carb. The carb slowly dripped or gas evaporated slowly from carb?
No smell of gas or sighting under carb on engine pan?
I never store with any smidgen of gas in tank and run dry
Oldbluoval is offline   Reply With Quote
Old 09-10-2021, 10:18 PM   #3
Eccentric Old Guy
Eccentric Old Guy's Avatar
Same thing happens to my motorcycles every year during the winter months.......always less than you had when you put it up for the winter.
However 2-3 gallons lost in a month is abnormal.
Oldbluoval above has an explanation that seems reasonable.
Eccentric Old Guy is offline   Reply With Quote
Old 09-11-2021, 03:52 AM   #4
ronn
inlaws are always suspect...........
sounds like grandma was out joy riding!
Old 09-11-2021, 04:09 AM   #5
aermotor
I fill mine to the top after every use from a near by 5 gallon gas container. It may help to prevent rust and does help prevent condensation - never had a problem. With the price of gas today you might revisit the foul play aspect. If still having problems check the above comments again.
John
aermotor is offline   Reply With Quote
Old 09-11-2021, 05:39 AM   #6
Patrick L.
Patrick L.'s Avatar
Gremlins, common problem, those pesky little guys.
Old 09-11-2021, 03:08 PM   #7
skeazle
I didn't want to park the car with a lot of gas cause I wanted to pull the carb and replace the large paper gasket. I only had it stored there for a month or so but the last couple gal. disappeared. Kind of a weird thing. The carb had been leaking with the tank full but when I got it out the carb was completely dry. So now if I fill it up with gas maybe it will start leaking again. I'm sure that is probably the explanation. I will change that gasket and put in a new screen while there is only a gal. in the tank.
Old 09-11-2021, 03:12 PM   #8
Redbird
Redbird's Avatar
Faulty shutoff valve for sure. Gas leaks to carb and float not set to shutoff & leaks on the floor and evaporates.
Redbird is offline   Reply With Quote
Old 09-11-2021, 03:22 PM   #9
Mad Mac
Next time you fill the tank wait a few minutes then put your finger on the tank just below where the steering column support bracket connects to the tank. A slow leak there is very common with Model A's and over time the petrol would evaporate without leaving a puddle.
Mad Mac is offline   Reply With Quote
Old 09-11-2021, 04:25 PM   #10
Patrick L.
Patrick L.'s Avatar
If the carburetor was dry then it sounds like two issues, fuel valve and float valve.
Old 09-12-2021, 09:03 AM   #11
Badpuppy
Seepage here may leave no puddle but does leave tracks down the tank. Smell too with the windows closed.
Badpuppy is offline   Reply With Quote
Old 09-12-2021, 09:57 AM   #12
Ed in Maine
I have a 1914 Model T which has a shutoff valve at the bottom of the tank. It doesn't drip on the floor but it always has a "runny" nose! I put the car up for the winter in October with a full tank. I was astonished to find that the tank was empty the following June with no stains on the floor. That slight smell you have in the garage is a significant leak. Ed
Ed in Maine is offline   Reply With Quote
Old 09-12-2021, 02:24 PM   #13
skeazle
Thanks everyone for all the helpful advice. I have replaced the fuel shut off valve a couple years ago and when it was new it would turn real easy but now it is really hard to turn on or off. So that might be the problem but if it was dripping on the floor and evaporating wouldn't there be a gas stain on the floor? I think I'll replace the shut off valve and hope that does the trick. thanks again, Jim
Old 09-12-2021, 06:14 PM   #14
nkaminar
nkaminar's Avatar
There is something called EZTurn which is a lubricant for use in petcocks. It does not dissolve in gasoline. You can take your petcock apart and use this product to seal it and make it easy to turn. It is also handy to seal and lubricate gaskets and other parts that are subject to gasoline. See https://www.aircraftspruce.com/catal...ezturnlube.php
Old 09-12-2021, 06:57 PM   #15
aermotor
Hey Neil. I have used that lube in my past aircraft days and it is excellent. We
also lapped the valve with Comet kitchen cleanser. My car is still running great.
John
Old 09-12-2021, 07:35 PM   #16
JayJay
Originally Posted by aermotor View Post
We also lapped the valve with Comet kitchen cleanser. My car is still running great.
John
The Comet cleanser of years ago used to have a little bit of sodium borate (aka Borax) abrasive in it. Lots of great uses for a mild abrasive like aermotor suggests. I just looked at the can of "scratch-free" Comet under my sink and alas, no sodium borate listed. Things just aint the same as in the good old days...
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is offline   Reply With Quote
Old 09-13-2021, 07:33 AM   #17
eagle
eagle's Avatar
As others have said, the fuel vavle isn't sealing off. The carb will likely be damp and will evaporate enough to not drip. Also an occasional drip will be caught by the engine pan, then evaporate from there.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-13-2021, 12:16 PM   #18
katy
katy's Avatar
Will red rubber grease work on the fuel valve?
