09-03-2010, 09:55 AM | #1 |
oil pump cam gear
Hello, I have taken my 59 a down to re-gasket and clean and inspect.I have the cam with the press on oil pump drive gear.There have been a few problems with the gears slipping. I have read about pinning the gear does anyone have a pic.of this. can you drill between the cam and gear put in an allen set screw.Thanx in advance Pete.
09-03-2010, 12:06 PM | #2 |
Re: oil pump cam gear
Mine is a 8CM but the engine is tore down for rebuild. Cam's oil pump gear is loose and sloppy on the stub. Builder said don't risk fixing it, so I got a new cam.
If yours is tight you should be ok. I'd like to Zap my new cam gear with a spot weld of some 7018. But I'm not going to. Gene |
09-03-2010, 12:41 PM | #3 |
Weld it, and good to go, been there ...........OLD.....BILL
09-03-2010, 02:02 PM | #4 |
I would NOT weld it....The cam is cast iron and the gear is steel..The gear is carburized and welding heat will draw the temper.
I pin the gear on race engines by drilling on the parting line and tapping for a 8-32 set screw..Loctite the screw and peen over the edge of the hole after it is in. |
09-03-2010, 07:20 PM | #5 |
thanx Pete!
09-03-2010, 09:12 PM | #6 |
